Question about Nikon D70s Digital Camera
Blob on photos
I have a dark blob appearing on photos,no matter which lens I use. I have also cleaned the inner lens, does this mean somethig has got inside the camera? Will it be a pricey repair?
Thank you
  • janesltaylor Feb 22, 2009
    Thank you so much.
    I am pathetically incompetent when it comes to my camera, so I will search for a good camera repair near me, not easy when you live in the back of beyond
    Thank you again
    jane
    President:
  • 423 Answers
Sounds like you have your "blob" on the actual CCD sensor in the camera. There are special "cleaning kits" to remove dust etc. from the sensors without damaging them. I would not suggest trying a "home-brewed" system of cotton swabs, isoporpyl alcohol, and a can of compressed air, unless you were very well versed in this operation. A scratch on the sensor will ruin the camera. Have a qualified shop do it, or buy the sensor cleaner kit, if you want to be safe.
Posted on Feb 22, 2009
How to take the lens of my nikon L25
From a look at the spec, neither the lens nor the back of the camera can be removed except by qualified technicians. Have you tried your local camera repairer ?
Tony
Dec 10, 2015 | Nikon COOLPIX Cameras
Viewsonic 5132 dust blobs
Most likely your DMD chip has dust or hair on it. You can try blowing it out with compressed air but the best thing is to tear down and clean the dmd chip itself. Very carefully. Here is a video of a similar unit. SO far all the DMD projectors I have worked on have had a very similar set up. Take pictures as you go.
MItsubishi XD206u DLP Projector Lens Assembly Cleaning
Mar 14, 2014 | ViewSonic PJD5132 SVGA 800x600 DLP...
Bubbles are projected on the screen
I am assuming that the "bubbles" are most prominant when the picture is dark. If that is the case, it is most commonly referred to as dust "blobs". Dust particles get on the lens assembly inside the projector and are just out of focus so they appear as blobs or bubbles. If you can carefully remove the cover and gently blow out the lens / color wheel area with compressed air it should reduce the "bubble" effect. I would not recomend any further dissasembly as it is complex and time consuming and unless your very careful, could end in disaster. Don't forget to clean the air filters either.
Aug 03, 2011 | Optoma EP721 Projector
A blob is appearing on every frame could that be dirt on the sensor? If it is dirt on the sensor, how do I clean it?
First of all, you can't get to the sensor to clean it. Is the blob in the same place on each picture? Is your lens clean? Does the blob actually appear on prints you make?
Dec 24, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Sir i have purchased nikon p100 camera from croma stores belapur branch , the problem with the barrel and there were gear noise and on taking photos in dark back ground of moon there were several white...
You have to know the MODE your camera is in. If you have it in the wrong mode you may not be able to take a photo in some conditions. You typically cannot take a photo of the moon on any auto setting the moon will be a white blob. The moon almost has to be taken manually.
Search for Lens Error. There are many was to fix Lens Errors
Mar 15, 2017 | Nikon Cameras
Mark on screen and photos
this is a fault with the ccd this is deep inside the camera if it has dust on it you may get a cheep fix done if not its going to be pricy?
Jul 04, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
Tiny black dots and a hairline mark now appear on all my photos using a Nikon D40
You might have to have your sensor cleaned. When the camera body is exposed to excessive amount of dust they can get in the mirror housing. When the shutter opens and the mirror flips out the way when a photo is taken, it aggitates the dust then it falls on the sensor. It will need to professionally cleaned by a repair technician.
To test it is dust, take a few photos of a white wall at aperture f22 with the flash on and if they are all consistant that is problem. They will look like soft black blobs.
Oct 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Vp800 LCD Projector has dark blob on display.
blow out any dust with canned air. chances are there is an object blocking the image. or there is a crack or burn spot on the 2nd fly-eye lens (diffuser). the first one is right next to the lamp (if you remove the lamp, you'll see it). the second is right on the other side of it.
Jul 14, 2009 | Office Equipment & Supplies
Hi, It appears there is a small amount of fungus inside my lens, and when taking a picture, it comes back very dark. What would a possible remedy be for this? Many thanks Jon
This is actually a very common situation for older lenses. You should take the lens to a trained technician and have them clean the inner elements of the lens. Often times they can, if the fungus isn't too bad. In extreme situations, they will need to replace the element itself.
Jul 05, 2009 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
A small dark blob, exactly circular, translucent, fuzzy outline, which is on every pic.
Same problem here too! dark spot and what looks like dust appearing on all pictures. Comes into sharper focus on extreme zoom.
Feb 24, 2008 | Ricoh Caplio R6 Digital Camera
Nikon D70s Digital Camera Logo
77 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
