Question about Kirby Ultimate G Bagged Upright Vacuum
Vacuum g6 won't turn on
I have plugged Vacuum in and it won't start. Is there a reset button? Help
  • 134 Answers
Hi
Either the bag or the main head is not locked on correctly
Posted on Feb 22, 2009
Shark professional nv355 wont turn on
could be the motor thermostat. Make sure the unit is clean. No dust build up in the filters etc. Then here are the motor reset steps.
Motor Thermostat needs resetting
In order to reset the Motor Thermostat:
  1. Move the Power Button to the "O-Off" position
  2. Unplug the vacuum
  3. Check for a clogged hose or filter; unclog the hose and replace the filter
  4. Wait 45 minutes for the vacuum to cool; then plug the vacuum
  5. Turn the power switch to the "I-On" position to start the vacuum
  6. If the vacuum still does not start, contact Customer Service at 1-800-798-7398
Jan 10, 2018 | Shark Vacuums
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
My G6 after turning on does not run untill you rotate the beater brush
sounds like the drive belt has been overstretched. replace with a new one and see if that helps.
Jan 08, 2014 | Kirby G6 Bagged Upright Vacuum
Reset button power
Reset switch is located on the back of the vacuum and close to the back wheels.Press a reset switch a few times and vacuum should start. Check also cord plug . Many times metal prongs are broken at the end of the cord (usually one of them)
Nov 28, 2013 | Riccar 4812 Vacuum
Electrolux ultraactive vacuum won't start
Hi There, The E2 error is caused by the terminal block pins where the hose plugs into the vacuum become bent out of shape. This is the receiving pins at the front of the vacuum on the inside. If what I am saying is confusing then it probably needs to go to a technician, it is a 10 minute job to fix if you have done it before. There is also a slim possibility that you may need a new hose for it too. If you are in Melbourne I can fix it I run the VacuumSpot business.
Jul 06, 2013 | Electrolux Vacuums
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Is there a reset button for Kirby G6?
One set button on your Kirby. Remove the head to check for blockage in the fan.
Aug 14, 2012 | Kirby G6 Bagged Upright Vacuum
My S5211 is 5 months old and was running perfectly. Last weekend I took it out to vacuum house but it would not start. I checked the fuse in the plug but it was fine. I replaced the dustbag but still it...
if you put everything back in place properly it should be working,check dust bag properly seated, and cover reseated, still not working do as planed, take it backto the shop, hope this helps
Sep 01, 2011 | Miele S5211 Deep Black Vacuum Cleaner...
Wind tunnel hepa filter it stopped during my vacumning. It was plugged so I cleaned the plug but it won't start again. the outlet has power??
let the handle all the way down look down at the vacuum head you should see a reset button reset it and see if it won't turn on then hope this helps
Jun 30, 2010 | Hoover U6630-900 WindTunnel Bagless...
Kirby Ultimate G Bagged Upright Vacuum Logo
130 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
