Question about Homelite Mighty Lite Lawn Trimmer
Homelite mighty lawn trimmer starter cord
I need to rewind or replace the starter cord. I cannot figure out how to access it. I have loosened the engine and housing. How do I release the shaft?
3 Suggested Answers
steve_lima
  • 181 Answers
SOURCE: Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Posted on Jun 02, 2009
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
Homelite weedeater pull cord wont retract once ive pulled on it to start
you will need to remove starter cover & boom assy ,
sounds like either the rewind spring is broken or the pulley has split at the base of pulley or the starter pawls are bent / jamming , check that the centre pivot if this unit uses this type is not binding , pulley should be free , check the pulley is not damaged ?
either way once cover is off you should be able to see the problem
check the lugs that secure the pulley to the cover if unit has 3 lugs that secure to the cover ?
replacement parts should be available reassemble and test
cheers hope it helps paul
Jul 17, 2010 | Homelite Mighty Lite Lawn Trimmer
Starter cord will not recoil
Sounds like either something is caught in the spool or the recoil spring is broken or the rewind spool is broken. You have to disassemble the unit to see. Do that and I think you will find the problem. When you do find it and need more help, please ask. Good luck...Lee
Jun 11, 2010 | Homelite Mighty Lite Lawn Trimmer
Pull start
Good chances is that the cord either got pulled to far out or the spring let go inside the cover that controls the rewind. It's not a big job...just remember how you took it apart www.nnyparts.com
Jun 01, 2010 | Homelite Mighty Lite Lawn Trimmer
After turning of engine. Starter pull cord stuck.
The recoil spring that rewinds the cord may have broken of pulled loose from its mooring.
Sep 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
How do I take the UT20816 trimmer drive clutch off? Need to replace the spring for the starter cord rewind.
on my trimmer I took the motor off and there was a cable trans. with a silver-colored plate with 3 screws. I took them off and there was the starter cable and the spring (Caution it my pop out on you).
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Can not figure out how to restring
im pretty sure i have the same trimmer, take the spool off, take all the cord out of it, now look closely at the bumper, u should see an arrow, find the halfway and fold it so it 2 peices, dont cut it, and rewind the cord, ull see clips on the bumper thats for when ur finished itll hold the line back in place so u can put it on without hassling with the cords, once u get the bolt on and tightened, give those 2 cords a good pull and they will pop out of the clips and u should be good to go, if this doesnt help ya, there is a tutourial on fixing these on youtube.com
May 08, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
464 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
