Question about Lexmark X2500 All-In-One Printer
It keeps saying remove jammed paper but there is no jammed paper anywhere i have done everything except take it apart
    Genius:
  • 2,035 Answers
Please try these steps if you have already tried these steps then its hardware failure on your printer....
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Feb 25, 2009
Paper jams almost immediately after I print. The message says "200.33 paper jam, remove cartridge", which I have done over and over, with no results. There is no paper stuck anywhere, as I have...
It is probably a fuser issue, Once the paper path goes past the fuser, an gunked up fuser will not let paper go through. Did the last few copies of the paper look bad?
Jan 27, 2011 | Lexmark E350d Laser Printer
My printer is saying "Carriage Jam" and that I should remove Jam and press okay. I can not see a jam anywhere and have tried everything. Do you have any suggestions?
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things.
Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside.
Also the paper being used should be as per the manufacturer's recommendations.
Turn off the printer when removing bits of paper.
If there is a broken gear, do not repair it yourself. Call an expert technician to mend it. get more help for HP Carriage Jam .
Sep 20, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
CARTRIDGE JAM - CARRIAGE JAM - PAPER JAM - RESET POWER
change the carrage block will solve this issue.the carrage block cable is damaged
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Brother 2920 Fax Machine keeps jamming every few pages
Please try this and let me know how it goes
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
My printer keeps on jamming, says I need to re-align the paper, which i've done but the paper won't feed through. Someone please help. Thank you! Anna
Try cleaning all the rollers with 90% rubbing alcohol, as well as any tight spaces on the printer... Use Q tips. Also inspect rubber rollers for wear and replace any worn ones (they're not expensive).
You may also have some paper jammed deep in there. taking the printer apart and cleaning everything with rubbing alcohol should solve that.
Apr 14, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
