Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Encryption Process? I installed my DI-624 two days ago, but noticed that it is not encrypted. When I go back to 192.68.0.1, I get a message that says: To view this page, you need to log into area 192.68.0.1:80. Then it asks for a name and password and I can't get by this. Any help would be greatly appreciated. artfuld@frontiernet.net
  • artfuld64 Feb 23, 2009
    No, I didn't. I was was using admin/password and it was rejected. I'll try your suggestion and let you know. Thanks!
  • dervari May 11, 2010
    Did you change the username and password? The default user/pass is admin/admin. Have you tried that?
Just Enter admin and leave the password empty and just enter,
Kadafi.
Posted on Mar 24, 2009
The computer will not be able to pick up the D-link network I have set up if I switch the modem and router off. Even when I leave it running it will sometimes not get picked up.
try changing the encryption type. This sounds like the computer your using does not support the encryption type being used by the router.
1. Go to the setup screen of your router. For a D-Link router, you typically fireup your browser, go to http://192.168.1.1, and type in your username and password, my default username and password is admin, admin.
2. Click on the Wireless link. It will open Wireless settings.
3. There are options to let you set your Encryption Preferences. You can provide an encryption key that will be used by the router and any PC that wants to use the network.
4. select none. (if your wifi now works then you have found your problem and you can try the alternate encryption type, either WPA or WEP)
Mar 01, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
How do I obtain the WEP Code for this Router? I'm trying to hook up my Internet capable LCD TV
Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
Click here if you cannot access the web-based configuration.
Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key.
Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption.
  • 64-bit encryption 10 characters
  • 128-bit encryption 26 characters
  • 256-bit encryption 58 characters (available on DI-614+ only)
  • The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key).
    Step 5 Click on the Apply button then click on the Continue button to save your settings.
    Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
    How do I enable encryption on my D-Link adapters?
    If you need more help come back.Post /thumbs / testimonial are welcome!
    Nov 23, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Are trying to enter the WEP key and it is not allowing any more the 5 characters (please input 64 bit WEP encryption and Five ASCII Characters))
    It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption.
    Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead.
  • Jun 25, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Where or how to find the network key?
    use a wired computer. open your internet browser then go to http://192.168.0.1 by default, the username and password is admin and admin.
    next, go to the wireless / security section then look for the WEP encryption or the WPA key.
    hope this helps.
    regards,
    voodoo
    May 09, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Encryption of Di-624
    You can download the manual for this router (revision A1) from here.
    Look at page 13 of the manual, which describes how to set up your wireless network.
    Note that you only have 128bit encryption, not 256bit!
    To see the differences (especially in characters and the number of characters) and to generate a good key, have a look at this page.
    If you have any more questions, just come back here and leave a comment - I'm happy to help!
    Mar 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Router Security
    Once you connect to your wireless network and it ask you for a password or if you notice that your wireless network name has a lock on it or says it is secured. It means your wireless network is secured. Otherwise reconfigure your wireless to enable wireless encryption.
    Jan 10, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Laptop cannot connect to router with WPA-PSK security
    What I believe here is you are not typing in the pass-phrase(wireless password) correctly.
    Go to 192.168.1.1 log on to the router ,in wireless section you will find the pass phrase,, create a new one and then try to connect.
    Jun 09, 2008 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
    Change from default
    I am going to make some assumptions here first is that the hard drive was added to or replaced in your computer by a store or by a friend. Is it possible that the installer altered your network card configuration eliminating the encryption settings required to be set in your computer for your wireless adapter card to connect with the router in your home? If so I would suggest reinstalling encryption in both your wireless router and to your computer for its adapter card as you did initially to get them working. I find it annoying too when service personnel change my computer's settings and do not set them back to their previous settings when they have completed their work.
    I hope this helps.
    Dec 01, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
    WEP Encryption
    It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
    Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
    WEP Encryption
    Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
    D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
    131 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
