Question about Maytag Neptune MDE5500AY Electric Dryer
MDE5500AYW MAYTAG DRYER WON'T START
I have a maytag neptune dryer. I put a pair of basketball shoes in it with some sheets and now it stopped working. All the lights go on, but it won't start a cycle. when I push a button it beeps but won't start. I tried unplugging it for a while and when I plugged it in it said "PF" for a second. Any ideas?
  • 1 more comment
  • Anonymous Feb 22, 2009
    Exact same thing just happened to me???
  • tchurkids May 20, 2009
    I have the 9700AYW model, but I have the same issue. ....started out the same way, with a pair of tennis shoes
    ooops, not quite... no PF ..... just won't start....lights up, dings like it should when you start it, but it doesn't start
  • 686 Answers
Pf means power failure. your dryer uses an extra boost of power on start-up and your is failing to get this boost you need a repair person in your area
Posted on Feb 23, 2009
MDE5500AYW Maytag Neptune not heating. Heating Element, both high limit thermostats and thermal fuse have been replaced. What could be the problem?
Firstly, you have not mentioned that you have verified the presence of a power source of 240 volts, so make certain of that issue. If you have proper voltage, then the motor centrifugal switch could be at fault
Below is a link for trouble shooting your model.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-563862-/Maytag-Dryer-not-heating-MDE5500AYW?r=%2fShop-For-Parts%2fa8b4d563862%2fModel-MDE5500AYW-Maytag-Dryer-Parts
Sep 28, 2016 | Maytag Dryers
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
Dryer running fine but just stopped heating. lint traps all clean.Maytag Neptune MDE5500AYW. HAVE THE DOOR AND FRONT PANEL OFF ALL ELEMENTS LOOK CLEAN AND ATTATCHED. No problem with home power...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 23, 2011 | Maytag MDE5500AYW Electric Dryer
I have a Maytag Neptune clothes dryer and have had it for years with no problem, love my dryer!!! However, this morning I tried to dry some towels and a code 8.8. displays on the display screen.. Please...
There is a technical sheet inside your dryer's cabinet. You can usually find it by accessing the rear of your dryer. All the fault codes should be explained in this paperwork.
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer won't start/
I do not have that specific dryer but try these simple steps.
Maybe they will help you.
1. Shut the electric breaker off to the dryer for about 30 seconds and and back on.
2. Open the dryer door and inspect the switch that tells the dryer the door is closed. work it by hand just to make sure it is not stuck.
3. Spin the timer controls to another setting and see if the other setting will work.
That's all I've got for now...
May 20, 2009 | Maytag Neptune MDE6700A Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
676 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
