Question about GE Microwave Ovens
GE Profile over range microwave jvm2070sh001 - no power or lights
Acts like it is unplugged, but verified power to the unit - just stopped working. No lights or anything. I know there are a couple internal fuses, no clue why they would have blown? Ideas? Thanks
  • wvgrbc Feb 22, 2009
    I checked the fuses and they were fine. Pulled out the little paper troubleshooting guide with flow chart. Looks like the problem is probably one of the thermostats (TCO - thermal cut out or temp sensors). Guess I'll have to pull it down and open it up to see which one is providing the open circuit.
  • wvgrbc Feb 26, 2009
    okay, got the new TCO thermoal cut out today. Replaced it, and now....still no lights on the display, but the vent fan is running - and I cant turn it off? Help please.
MicrowaveSvc
  • 9086 Answers
SOURCE: GE Profile Model # JVM2070SH001
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
Draic
SOURCE: GE Profile over the range microwave
I have a GE space maker the model number is JVM1860.
Same grinding sound when truntable is turning. Stops when you turn turntable off.
Can this be fixed by a layman?
Posted on Jun 10, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Posted on Feb 08, 2009
  • 10865 Answers
SOURCE: I have a GE Profile spacemaker 2.0 microwave and
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Posted on Jun 23, 2009
hiltonjug
  • 612 Answers
SOURCE: GE model JE2160BF03 no power. Blown fuse.
They are put out when something metal is put inside and cooked for a few min. They are also put out with power surge. It protects your mag tube. Plus they just go bad sometimes. Could be a number of reasons but these are the most common.
Posted on Nov 17, 2009
I have a GE JVM2070SH001 micowave . I do not have power to the under unit lights (work,nitelight) but everything else works fine. What is the likely problem?
Either the control board or the switch itself. I can't remember if that on is part of the main keypad or not. Does the unit beep when you press the light button? If it does then you need to follow the wiring to a point where you have power. Best guess...control board
Dec 05, 2012 | GE Profile Spacemaker Over-the-Range...
Key pad on my GE Profile Spacemaker 2.0, Model JVM2070choo1 does not respond.
1) the control board is faulty. however you can try to clean the keypads for dirty , oxide, or corrosion, Of course you must try to unplugged the power cord and discharge the capacitor see the diagrams.
God bless you
7_15_2012_12_27_54_pm.jpg7_15_2012_12_28_09_pm.gif7_15_2012_12_28_43_pm.gif7_15_2012_12_29_12_pm.gif
Jul 14, 2012 | GE Profile Spacemaker Over-the-Range...
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE PROFILE SPACEMAKER 2 JVM2070SH001 MANUAL HOW DO i REPLACE CHARCOAL FILTER?
That's covered in the owner's manual. If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
You can find handy exploded views and order parts (including filters) here.
Jan 10, 2011 | GE Profile Spacemaker Over-the-Range...
Ge profile spacemaker 2.0 model#JVM2070SH001 - HOW TO REPLACE CHARCOAL FILTER.
My microwave GE Profile Spacemaker 2.0 keypad does not work, I unplugged it and reconnected it and it works at times for a while then it stops again.
You have a failing membrane keypad.
To help you further, I would need your brand and the full model number from the tag on the unit.
It's best to repost a new message to FixYa or contact me directly.
Dec 31, 2010 | GE Profile Spacemaker Over-the-Range...
I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
May 27, 2010 | GE Profile Spacemaker Over-the-Range...
JVM2070SH001
you have a bad magnetron. go to sears parts direct and you can see the price for a new one. but it may not pay tp fix.
Feb 25, 2010 | GE Profile Spacemaker Over-the-Range...
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
439 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
