Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore dishwasher 665 Lock on light
My Kenmore 665.16817 s/n FX2506742 dishwasher Lock On light keeps flashing. I have pressed the No Heat Dry button and held for 4 seconds or more getting the Cancel light to also come on and now they are both flashing.
This situation came about over night and now I can not use the dishwasher.
I had Sears service come in and claim that I need a new control panel. $372. Ouch.
Is there any hope.
Thank-you
  • Ken Roberts
    Ken Roberts Feb 22, 2009
    I have the same problem
  • 708 Answers
You may have a stuck button as this will cause flashing of lights, try pushing button and see if it returns if not strike lightly above it with plastic spoon etc.
If this does not work u can buy the control panel from Sears for 190.00 but first go to searspartsdirect.com then type your model no. In required space click on shop parts on appropriate model, then go to troubleshooting then to won't start, then go down to how to replace control panel.
According to instructions you will only need torx screwdriver and less than 30 minutes to replace.
Posted on Jul 14, 2017
SOURCE: blinking lights on kenmore 665
key pad need to be change
Posted on May 09, 2008
  • 110 Answers
SOURCE: Sears Kenmore model# 665-16022401 Serial# FS0304946 - Clean Light Blinking
THE HUMMING NOISE THAT YOU ARE HEARING IS THE ELECTRONIC DRAIN MTR ACTIVATING BUT YOU HAVE NO WATER IN THE SYS. SO IT SOUND LOUDER AND DIFFERENT THE HUMMING IS THE LESS OF YOUR WORRIES THAT IS NORMAL BUT WHAT IS NOT NORMAL IS THE CLEAN LIGHT FLASHING IF IT FLASHES 7 TIMES THEN PAUSES YOU HAVEA BAD PROCESSING BOARD AND ALSO A HEATER ON SOME OF THE KM MODELS THE CONTROL BOARD AND HEATER IS SOLD AS A KIT. TO VERIFY THAT THIS IS THE CASE GO TO WWW.SEARSPARTS.COM . BUT FIRST ALSO CHECK TO SEE IF YOU HAVE A BURNT WIRE AT THE HEATER ASSEMBLY WHICH WOULD REQUIRE PULLING THE DW OUT. GOOD LUCK
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
mattozan
  • 555 Answers
SOURCE: My Kenmore Dishwasher Model #16769000
Try unplugging and replugging to reset (or, if the plug is too difficult to reach, reset the breaker)
Posted on Jul 07, 2008
  • 338 Answers
SOURCE: ''lock light on 665 17779990 Kenmore dishwasher will not turn off''
stuck key pad. the control panel will need to be replaced.
Posted on Mar 04, 2009
SOURCE: lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Posted on May 28, 2009
The normal wash cycle keeps flashing, and no other butten you push will change the flashing of the butten. Is there a reset butten, Or can I shut off the power and turn it back on to cycle it. This is on...
Hi
Press and hold the HEATED DRY/NO HEAT DRY/AIR DRY button for 15 seconds to unlock the control lock in your dishwasher. Also make sure that nothing is blocking the drain pump assembly. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 09, 2011 | Kenmore 24 in. 15079 Built-in Dishwasher
The lock symbol light is on and the dishwasher won't start
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Lock on light flashing. Dishwasher will not do
Hi
This is a child lock feature to stop unwanted operation of the buttons. The usual way to cancel this on a Kenmore machine is to press and hold the "No heat dry" button for longer than 4 seconds. This should cancel the lock and resume normal function.
Hope this helps. Please do rate this answer. Thanks.
Aug 16, 2009 | Kenmore Dishwashers
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Kenmore dishwasher LOCK ON light will not stop flashing
is that the button closest to that lock light? if not it may be a button closer to the lock light. if it still doenst work you may have a short
Nov 21, 2008 | Dishwashers
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
132 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
