Question about Dell Latitude D620 Notebook
My Dell notebook monitor display's a small screen instead of full size. Any ideas why?
Try changing the screen resolution (right-click on desktop->properties->settings->ok) or searching on Dell's website under the support section for display drivers for your model
Posted on Feb 22, 2009
  • 129 Answers
This can be because of two reasons.
1) The horizontal and vertical size in the monitor settings might be changed to shrink the visible video size.
2) The resolution settings of the system might be at a very high level which makes the screen/font size very small. Adjust the graphics settings on your system accordingly.
    President:
  • 2,653 Answers
There are two main causes. Your display settings are incorrect or a video driver problem.
First thing to try is right-clicking with your mouse any clear space on the desktop, then choosing properties.
From there you'll see a tab that says "settings".
Just slide the bar all the way to the right. You might have more than one choice and you can always choose again so play around with it until you find the right display ratio for your screen.
Here's a little visual guide here:
http://www.ehow.com/how_4595009_change-display-settings-xp.html
If that doesn't work then you probably need to reinstall the drivers for the video. You can try the easy way by doing visiting the "Windows Update" page and performing a custom update. If there is an updated driver then you'll see it listed under HARDWARE.
You can go that route or if you just want you download the drivers direct from Dell support site here:
http://supportapj.dell.com/support/downloads/index.aspx?c=in&l=en&s=gen
If you still have questions just ask.
Best of Luck!
Dell sx2210 how do I change the size of the screen?
  1. Navigate to the Control Panel in Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
  2. In the Control Panel window, open Display. Note: In Microsoft Windows , depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that saysSwitch to Classic View.
  3. In the Display Properties window, click on theSettings tab.
  4. Locate the Screen resolution slider on the left-hand side of the window. Under most circumstances, the best choice is 800 by 600 pixels or 1024 by 768 pixels, possibly higher if you're using a 19" or larger monitor. The "best" setting is highly subjective to your personal preferences.
Aug 03, 2014 | Dell SX2210 21 inch Monitor
My internet explorer webpages have become really small on my 24 inch monitor and i dont know how to fix it like the font is size 6 or 8 or something and when i search for something on google there is like...
Hold the CTRL Key and roll your wheel mouse UP or Down to the size that is best.
In IE7/8 you can select VIEW, Text Size. on Status Bar (bottom right of browser) set to 135%
Set Display to 1680x1050
May 02, 2010 | Dell Inspiron 1100 Notebook
Display on Dell C840 has blackborders at low resolution
That should be normal. If you use a resolution that is lower then the physical device it will leave the edges black. If the screen printing is to small change fonts and icon sizes instead.
Sep 03, 2009 | Dell Latitude C840 Notebook
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Dell Inspiron 8200 Notebook
Xps m140 want higher resolution displayed tonew secondary monitor
Notebooks usually don't have high res . They trade off the high resulation  for the small size and less power consumption.
Mar 07, 2009 | Dell Inspiron XPS M140 Notebook
No showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Feb 16, 2009 | Dell E153FP 15" LCD Monitor
Need External Monitor to Work
The Fn +F8 combo will toggle between 3 options,
LCD
LCD and EXTERNAL
EXTERNAL only
Jan 25, 2009 | Dell Inspiron 8600 Notebook
1440 x 900 setting for monitor means I can't see my whole desktop on my toshiba laptop...
Not all laptops display adapters will allow the individual settings for a screen and a monitor to take effect correctly.
This happens especially when one is a widescreen and the other is a standard screen.
It seems your settings are taking effect on both screens at once instead of on each screen individually.
I assume you have adjusted te display sizes in your display settings ?
If so, did you adjust each display separately ?
You may also have to see if your display adapter has the most correct drivers. That may help.
Fran
Sep 15, 2008 | Acer AL1916W 19" LCD Monitor
Can't adjust display size on monitor
1st try Fn+F7 or Fn+F8 to expand the screen.
If that doesn't work, reinstall the video driver, available a support.dell.com
May 16, 2008 | Dell Latitude D600 Notebook
Dell Latitude D620 Notebook Logo
460 people viewed this question
Alun Cox
