Question about Ultra (31624) (ULT31624)
Free Viewsat Ultra FTA key - Ultra (31624) (ULT31624)
Missing alot of channels
Try updating your FTA receiver with the latest files/keys.
May 19, 2009 | Ultra (31624) (ULT31624)
Activation of keys on an FTAS receivers
Your query > "Instructions on how to install new keys and activate an FTA receiver using a 2GB Cruzer Micro Flash Drive with 3 smarth technology"
Generic responses:
1. depending on your FTA receiver (brand/model/version) (BlackBird, MultiStar, UltraStar, Pansat, Digiwave, Viewsat, Coolsat, Fortec, Ariza, Twinhan... or even clones) you would need to download the appropriate firmware/satellite keys using your PC & Internet connection;
2. links to firmware/satellite keys maybe available from your FTA receiver manufacturer's website or forums such as HashHU FTA
3. in your PC, unzip the downloaded firmware/satellite keys to a temporary folder;
If you are using a stand-alone hardware FTA box:
a. plug in your 2GB Cruzer Micro Flash Drive to one of your PC's USB port;
b. copy/paste the unzipped files in the root directory of the Flash Drive. Verify that you have the .bin or .pmg of whatever your FTA box is using;
c. remove flash drive from PC's USB port and insert into the USB port of the FTA receiver;
d. on the FTA box, using your remote, go to Menu, Settings or Sytem Information, keys, firmware or receiver Upgrade, select USB, select Flash, Save, Activate or Upgrade;
e. wait until the FTA box has uploaded to itself the new firmware/satellite keys;
f. reboot (power on/off).
If you are using PC-based FTA satellite receiver:
i. run your FTA receiver program;
ii. select for Tools/Options/Upgrade or Update;
iii. browse/direct to search in your temporary folder where downloaded files were unzipped;
iv. once found, click OK/Update/Upgrade;
v. in some brand/model/version, there is an auto upgrade/update feature which will download appropriate firmware/satellite keys if you are online.
Hope that the this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Viewsat Ultra 2000 missing spike channels
join a fta forum. You will find a lot of info. You need to do a sat scan
good luck!
Oct 03, 2008 | Yamaha HTR-5730 Receiver
Downloading lastest FTA codes for Viewsat receiver
just go to different site like http://currentbins.com/viewsat/ and than u'll know what to do.
Apr 28, 2008 | Televison & Video
Viewsat ultra 2000 setup issues
You can go HERE to get all the info on how to set up your dish.
Mar 13, 2008 | Toshiba 57H84 57" Rear Projection...
Need step by step guidance to fix my viewsat ultra 2000
user guides fta files bin files and factory files are all free to download never pay for a fix! go to tvkeyz.com and join for free all the help u need is there ! if this helps please vote for me
Feb 08, 2008 | Yamaha HTR-5730 Receiver
Mon recepteur fta viewsat ultra est bloque
As-tu le cable db9? Et qu'est ce qui apparait sur la fenetre de ton ultra quand tu l'allumes?
Feb 06, 2008 | Audio Players & Recorders
Can some 1 help me with my fta
Loading Viewsat Ultra Via USB Flash Drive
1. Load File(s) to your USB Flash Drive. (eg.. PFTAUSW-070911U.PGM)
2. Take USB Flash Drive and insert it into Viewsat Ultra USB Port (behind right
side door flap)
3. Using remote Hit Menu. Then Go to System Information -> Receiver Upgrade
and Hit OK
4. Go to USB and Hit OK.
5. You will now see a list of all the files located on your USB Flash Drive. Find the
file you need to load. (eg. PFTAUSW-070911U.PGM) and select it and hit OK.
6. Your Receiver is now being upgraded.
7. It will come up showing you not to power off the unit.
8. Once it has finished the receiver will reboot and you have upgraded your Viewsat
Ultra.
Dec 28, 2007 | Computers & Internet
Fta viewsat extreme dead.
I am using viewsat extreme 2000. After downloading the new program PC-STB. Front panel power has gone. Only rear light on. All view has gone.
Would you please send me by email, how can I solve this problem? I shall be grateful if you please reply.
Thank you.
-Rajesh
rkb@295.ca
Dec 11, 2007 | Audio Players & Recorders
Viewsat ultra
This is not the site for what you are looking for, you need the fta site. You can go to dss****** and search for any FTA sites, regarding the view sat. If you have anyone programming for you, you will need to take back. If you are trying to DIY then look for a FTA site that will teach you how to JTag your equipment. If im correct you may have to go inside to repair. If it does not reset then Jtag is the best option. I think dsstester or the other sites can help if you look in their forums. Hope this helps!
Sep 21, 2007 | Audio Players & Recorders
Ultra (31624) (ULT31624) Logo
1,007 people viewed this question
Top Ultra Computers & Internet Experts
Gareth Cockram
Gareth Cockram
just-ice
Alun Cox
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
