Question about Belling XOU592 / XOU593 Electric Double Oven
Diplomat integrated oven- 13amp?
Hi, i have a diplomat single integrated fan assisted oven, i had one in my old house a similar model which just plugged in by 13amp mains socket, this one has no plug on and seems to have thicker cable, can this be plugged straight in or do i need a proper cooker socket? model is AHY3601.
Thanks
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Posted on Mar 05, 2009
  • binraider Mar 05, 2009
    I expect that the old cooker was a gas cooker? so the electrical needs would have been small -that would be why it had a normal plug.
Hi I have a Diplomat elite single oven (AAA3490). When I put the oven on, it is not warming up. Everything else looks fine. Any advice would be appreciated
If you can hear the oven fan running but the oven is cold is is most likely to be the fan element at fault. If there is no obvious damage to the element it should be checked for continuity with a test meter.
Always isolate the appliance from the mains before investigating
Jan 22, 2011 | Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Diplomat ADP3702 cooling fan problem
It could be a fuse or thermal cut out, you can test it with a meter. you should have continuity through it, if not then it is faulty.
If you do not have access to meter, then if take a piece of wire and connect it to the fan terminal and connect the other end to the origin of the ceramic fuse or what ever it is, and it should work, you are in effect bypassing the part in question.
If it still does not work then you are going to have to investigate further, or call some one in.
Plz rate my solution.
Thanks.
Jan 03, 2009 | AEG B1180-4 Electric Single Oven
Replacing the element in a diplomat 5706 cooker
Hi.
You will probably have to remove the rear panel of the oven, this is on the outside that I am referring to, and you will see the 2 securing scews for the element, you might have to push the insulation to one side to see the screws.
This should solve your problem.
Please good feedback if this helps.
Thanks.
Nov 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Diplomat Select 620 single oven and no instructions
how do i remove the door to reseal the glass
May 14, 2008 | Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Belling XOU592 / XOU593 Electric Double Oven Logo
777 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
