Question about Microsoft Computers & Internet
System protection option is not coming in the system protection option of the system window , then how should i enable system restore.
  • 34 Answers
  1. Right-click My Computer, and then click Properties.
  2. On the Performance tab, click File System, or press ALT+F.
  3. On the Troubleshooting tab, click to select the Disable System Restore check box.
  4. Click OK twice, and then click Yes when you are prompted to restart the computer.
  5. To re-enable System Restore, follow steps 1-3, but in step 3, click to clear the Disable System Restore check box.
u CAN ENABLE OR DISABLE UR SYSTEM RESTORE OPTION
ENJOY
REGARDS RAHUL
Posted on Feb 23, 2009
Error code 0x0000034
Try this
Press f12 then advanced options, then Automatic repair or other options listed below:
From page 115 of your user manual-
Advanced options
Choosing this option presents you with another set of
options:
System Restore
? System Restore allows you to use a Restore point to
return the computer to a state at which it was performing
properly. Restore points are created:
? When new hardware or software is installed
? Manually by the user
System Image Recovery
Windows® will "Recover" the Operating system using a
specific image provided by the user.
116 If Something Goes Wrong
The Windows® operating system is not working
Automatic Repair
This feature automates the repair process. The Operating
System will automatically look for problems and repair them
if possible.
Command Prompt
The command prompt is a very powerful tool for advanced
users.
Startup Settings
In previous Operating Systems the majority of the options
found on this menu were available by pressing the F8 key
during the Windows® boot process:
? Enable low resolution video mode
Restarts Windows® using your current video driver at low
resolution. This allows you to reset your display settings
in the event they have been improperly set.
? Enable debugging mode
Starts Windows® in an advanced troubleshooting mode
? Enable boot logging
Creates a file that lists all the drivers that are installed
during startup
? Enable Safe Mode
Starts Windows® with a minimal set of drivers and
services. If the computer starts and runs in Safe Mode,
you will know the Operating System is most likely
working properly and that you should look to third-party
applications or drivers for the source of your problem.
? Disable driver signature enforcement
Allows drivers containing improper signatures to be
installed
? Disable early-launch anti-malware protection
Allows drivers to initialize without being measured by the
Anti-malware driver
? Disable automatic restart on system failure
Prevents Windows® from automatically restarting if an
error causes it to fail. Choose this option only if
Windows® is stuck in a loop where it fails, attempts to
restart, and fails again repeatedly.
SOLVED Recovery Your new PC needs to be repaired Boot configuration error...
Feb 15, 2015 | Toshiba Satellite C55T-A5123 Celeron N2820...
Windows cannot find
will the computer boot to an operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
If this fails you might use the system restore option
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Jun 07, 2013 | Computers & Internet
Gateway dx4710-05 will not start upgoes to repair , will not repair
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Gateway DX4710-05 PC Desktop
Acer aspire ast180-ud400
You have no stated what sort of problem?
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Acer Aspire™ T180 PC Desktop
System wont restore to factory settings
I assume your System Restore, in System Properties, System Protection isn't enabled/on. Use this procedure to turn on: http://windows.microsoft.com/en-US/windows7/Turn-System-Restore-on-or-off for future use. Also you may want to do a Disk Clean to free-up disk space for future System Restore space, if necessary. Use CCLEANER freeware at: http://www.filehippo.com/download_ccleaner/ This freeware program has some very useful tools, Look at TOOLS, STARTUP, to disable ALL unnessary startup programs to speedup starts and running of your machine.
Feb 24, 2013 | Acer Aspire X3400 PC Desktop
Not enough space on friends laptop
First you need to disable system restore on the drive to reclaim the missing space. To do this, you can do the following:
1. Go to Start > Control Panel > System
2. In System > Click on System Protection at the left side
3. In the System Protection Window > go to the System Protection Tab > then uncheck C: then hit Apply then OK
After disabling system restore, run disk clean up:
1. Go to Start > Computer > Right-click on C: > Disk Cleanup - make sure to check all of the files to be deleted to clear as much space as possible
2. After initially running Disk Cleanup you will now be able to see the More Options tab in the Disk Cleanup window > go to this tab then cleanup the System Restore and Shadow Copies to remove them completely
3. Enable the System Restore from the System Protection tab in System.
4. Resize the maximum amount of Shadow Copies that can be saved on the system, this will lock the System Restore feature from saving more than allocated amount. Run Command Prompt as administrator (go to Start > Programs > Accesories > then right-click on Command Prompt then Run as Administrator)
Set the maximum to whatever amount you feel is necessary. Setting it to 1GB should be more than enough for System Restore to create at least two restore points. Type the command: vssadmin resize shadowstorage /on=c: /for=c: /maxsize=1gb
5. Once this is done you should have reclaimed at least 30 to 40% of the missing space. Once the System Restore has been reenabled it will automatically create the restore points so there will be no need to manually create one.
Mar 22, 2010 | Compaq Presario Notebook
Main data folders changed to protected operating system folders
Restore your system to an earlier date.You can do it by: Start - Accessories - System Tools - then click on system restore.You can restore your system to an earlier date on which it was working properly.
Dec 22, 2009 | Microsoft Windows Vista Home Premium with...
I need to stop this message from cyber defender from poping up on my computer
  1. Run Windows Defender from Start Menu.
  3. Then click on Options link under “Tools and Settings” section. windows-defender-options.jpg
  4. Scroll down the “Options” page, and uncheck the check boxes of the following two settings: Use real-time protection (recommended) under “Real-time protection options”
    disable-vista-windows-defender.jpg Use Windows Defender under “Administrator options”
    uninstall-windows-defender.jpg Note that both options MUST be unchecked for the Windows Defender service in Windows Vista to be completely stopped. Else, only real-time protection is disabled.
  5. Click on Save button.
  6. A “Windows Defender is turned off” dialog message will appear, confirming that Windows Defender no longer runs. Once the Windows Defender is disabled, it’s sort of been uninstalled too, as any attempt to run the program will bring up “Windows Defender is turned off dialog window and unable to proceed to Windows Defender main window anymore. windows-defender-off.jpg
This guide can be found here: Click Here
Oct 27, 2009 | Dell Computers & Internet
Cannot turn protected mode on or do system restore
This will delete everything and set computer back to factory. Save all pictures, music, etc.
1. Copy all your files and documents to an external storage device.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. choose your country and click OK
6. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. "Next"
10. Click "Yes"
11. you will notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish"
May 09, 2009 | Toshiba Satellite Pro L350-S1701 Notebook
Need to help to clean my recovery H disk is coming almost full.
A hard drive is usually partitoned, one hard drive will show up as two. The recovery drive should not be messed with. Don't add files , nor delete files from that drive.
Jan 17, 2009 | E-Machines eMachines Desktop PC
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
71 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
