Question about Keurig B60 Coffee Maker
B60 just flashes not ready yet ,have unpluged and tried that small cup med. cup and menu thing nothing changed
Call Keurig. I spent 2 weeks trying to fix my machine according to the online solutions and finally broke downand called their customer service 186690102739 and they talked me thru thge reset and prime and now my b60 works like a charm. :)
Posted on Apr 25, 2012
    Problem Solver:
  • 9 Answers
There has to be water in it first off. See my solution on the B50 with a similar problem. Before the lights blink ready the top (K-Cup Holder)has to opened and closed. Then the lights should blink and it should say ready to brew. I wish I had included that in the previous solution on the B50.
Posted on Mar 05, 2009
What does brewing time off mean
You can try the reset for the B60. I do bot understand your original What does brewing time off mean??...
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Jul 02, 2014 | Keurig B60 Coffee Maker
My keurig coffee maker dose not fill cup..ex..small..med..lg..very little water comes out..makes coffe super strong
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 28, 2011 | Keurig B60 Coffee Maker
Our Keurig B60 displays "NOT READY Auto off set" and does nothing. What can we do to bring it back to life?
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 28, 2010 | Keurig B100 Coffee Maker
My Keurig B60 does not run at all. The screen comes on and says: Not Ready and also says auto off set. The cup lights do not flash. I cannot get the menu to come on. Unplugging it and plugging it in...
Not sure if this will help, but I had the same problem over Xmas. This was posted 8 Jan, and I cut/pasted it here. Sounds complicated, but it's not. Just print it off instead of trying to remember it! I'd be interested to see if you had the same 'codes' as I, and if your machine had hot water when it ran... I have not done anything since that post...
Patient: Keurig B60
Symptom: "Not ready" light is on. Reservoir is filled and needles are clean, so problem is not user related.
Internet search yeilded some hope for another Keurig machine. While turned off, simultaneously press and release the small and med button, then menu three times. You get into a programming/diagostics menu. As you scroll (via the menu button) mine says Ready 602, Brew 265, Autooff 099, Set 007, Set/set 099, Descale 099, and Menu 000.
While at 000, press the med button but do not release. Press and release menu and immediately press small, then let go of small and med together. Pump runs and water is circulating, but is cold. Not sure if it should be cold (just a test routine, etc) or whether the heater is blown or something more troublesome.
Anyone have any ideas/experience with this information (I have no problem in ripping the machine apart if I have to. It can't be that complicated!).
Jan 31, 2010 | Keurig B60 Coffee Maker
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
Aug 10, 2009 | Keurig B60 Coffee Maker
How can i change language to english
Press menu
press Med cup(arrow down) twice
Press menu
Then use small cup(arrow up) or med cup (arrow down) to scroll through the different languages.
Once you have found english press menu.
Press large cup (escape key)to exit menu.
Done!!
Sep 20, 2008 | Gaggia Titanium Espresso Machine
No ready que
I received my B60 from Ebay and when it came the "not ready" message was blinking. I called the company and honestly told them my problem and also mentioned that it was an Ebay purchase with no warranty. They fixed my problem for free anyway, and were very friendly. I will definitely consider purchasing more from them in the future based on this experience. We reset my machine by doing the following two steps:
1. Press the small and medium cup buttons at the same time then immediately press the menu button three times.
(the number listed there showed how many cups of coffee the machine had made--mine said 0:04 which was four cups)
2. Hold the medium cup button and hit menu button then the small cup button quickly while still holding the medium button then release the small and medium quickly.
Jun 09, 2008 | Keurig Special Edition B60 Coffee Maker
Keurig B60 Coffee Maker Logo
1,645 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Steve
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
