Question about FrancisFrancis! X5 Espresso Machine
Water is not running through
I inadvertantly let my maching run out of water. Now it is not working at all. The water is not running though. Any ideas?
  • saomiguel8 Feb 24, 2009
    I haven't used my X5 in a while and mine will not pump any water thru as well. I popped the top off removed pipe to boiler and turned system on and no water came thru. Pump sounds like it is working but nothing. Where do I look for the water sensor
    President:
  • 1,902 Answers
Replace your water sensor. If it runs out of water you can pop the water sensor and it will not allow any water to pass through due to the fact that it sends power to the water inlet valve and that is how you get water to flow and not flow into your system
Posted on Feb 22, 2009
My kenmore washer 70 series immediately empties when I run water into it what is the problem? I do not have how water so I am trying to run cold water into just the cold intake and have tried running cold...
This sounds like the water is siphoning from the tub. Raise or loop your drain hose up (at the back of your machine) higher than the highest water level of the machine
Jul 09, 2010 | Kenmore Washing Machines
My gas hot water heater runs out of hot water very quickly. what should I do .It is 10 years old and just started to do this.
Check the gas valve first, it may have inadvertantly been turned down. The knob should be red and have settings on it. If it hasn't been turned down, it sounds like it's nearing its end. Good luck
Dec 26, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Overtemperature
Flush the machine with water a few times with cold fresh water, by running the hot water cycle.
Apr 06, 2009 | Saeco Vienna Digital Coffee Maker,...
General electric washing maching
defective water pump, drain hose is kinked or clogged, the drain is clogged defective water level pressure switch
Oct 08, 2008 | GE Washing Machines
1999 toyota corolla
If you are running your ac, this may just be condensation from the air conditioner.  Do you see puddles in the winter, or when you do not run your air conditioner?  I live in a humid climate, and every summer, no matter what car I have had, I have experienced this same thing.  I have been told that it was just condensation, and as long as it was water (colorless/odorless) it should be fine.  Of course you should take it to a licensed mechanic to verify that there isn't something more serious happening.  As a temporary check, though, you might try driving around for 20 miles or so without the air conditioner on and then park for a few minutes and check for a puddle/leak.
Aug 30, 2008 | Coleman Mach 15 Air Conditioner
Tsr mach3 conditioner
The smell is because of the stuff growing inthe water from the air conditioner. When you run the a/c it keeps the water condensed on the coil. When you turn the a/c off and run just the fan, it allows the water to warm up and start evaporating thus allowing the goodies in the water to become airborn. It would be adviseable to have the unit disassembled and cleaned by a professional due to the obvious danger of mixing water and cleaning chemicals with electrical equipment
Jun 25, 2008 | Coleman Mach 15 Air Conditioner
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Machine leaks after my kid tried to run it with the water shut off
simple. the water inlet valve burnt out and more than likely melted. anyway it needs to be replaced.
Nov 08, 2006 | Maytag Neptune MAH7500WH Front Load Washer
Tub will not fill with water
That's Great Man. Thank you for letting us know!
Apr 29, 2006 | Kenmore 23822 Top Load Washer
FrancisFrancis! X5 Espresso Machine Logo
756 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
