Question about Sony Playstation 3 (PS3) Console
Controller USB not working?
Hello everyone, in the past few months I have continued to get messages saying that the maximum amount of power has been delivered and to unplug a usb device, and the red dots start blinking on the controller but then I get control again.
Since then, the battery has been slowly dying even though I always have the controller plugged in, and now the controller doesn't work at all any more, when I first turn on the system the controller starts to charge but after a few seconds it stops and says the battery is low, then it dies.
Can anyone help me with this problem? I have never stepped on or thrown the controller.
  • Anonymous Feb 22, 2009
    my usb is not working i can't do anything on usb but my controller work not for long time coz i can't charge it :S
    President:
  • 2,653 Answers
Flip the controller over, and press the reset button. It's to the right of the middle-top screw Controller USB not working? - ps3_controller_reset.jpg. You'll need something like a paperclip, toothpick, or something similar to push the button. Once you've reset your controller, connect it to your PS3 with a handy USB cable, and press the PS button (just like you did when you first got the controller). Now, it is paired again, and you should be OK.
Grabbed this from Kaivarri. Thx!
Check out my new common problem and easy repair and tips guide here:
http://rescuetechla.blogspot.com/
If you've got any more questions please feel free to email me. Don't forget to rate!
Thanks!
Posted on Feb 23, 2009
How do I get this controller to connect in slot one? Need a manual on-line to go to for free?
Found this solution on a message board I had someone bring one of these into work a few days ago, saying it wouldn't work.
This is how I got it to work:
1. Put batteries in it (obviously)
2. Have everything powered down.
3. Put the USB Receiver into the front USB port.
4. Turn on the PS3, let it boot to the desktop/XMB/whatever.
5. Turn on the controller.
6. Hold down the "Home" button (the one that should the the one with the PS symbol on it) for a few seconds
7. Hold down the "Sync" button for a few seconds.
I believe that's how I did it. The manual seemed to offer fairly vague directions on syncing it. If you did it right, the LED on the top of the controller should be lit, letting you know what player slot it is assigned to.
Let me know how it goes.
Mar 21, 2011 | Intec PlayStation 3 Turbo Shock III...
When I attempt to download photos onto my laptop I either get a message saying the USB hub cannot take the power level required or there is no recognition at all. Any suggestions?
You might want to consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 20, 2011 | Vivitar ViviCam 8400 Digital Camera
My ps3 controller is not charging. Whenever I try to charge it, a message comes up saying " The maximum amount of power has been reached, please remove one device. The only "device" I have is the usb...
This is a problem occurring in all the play station 3 consoles....... this is mainly because of the poor quality of the disc .........avoid using pirated discs.....as a result it leads to the damage of ur PS3 lens..............use good original discs........
check your lens if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 will not load up the green light comes on but nothing happen a few minutes later it says 'cannot start correct hard disk was not found' can anyone help on how to fix or how to recover my...
Try this, but keep in mind that one of the options wipes all your data.
These should be safe to use, and 'should' keep your data.
  • Restore Default Settings
  • Restore File System
  • Rebuild Database
  • Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
    Step 3:
    1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
    4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
    5. Then you will see the Safe Mode menu.
    Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    1. Restore Default Settings
    2. Restore File System
    3. Rebuild Database
    4. Restore PS3 System
    Oct 04, 2009 | Sony Video Game Consoles & Games
    My ps3 has a message saying (the maximum amount of power that can be supplied to usb device has been reached remove at least one device) what is the problem.. it does this when i have my controller hooked...
    how many gigs is your PS3 and are you using a offical PS3 usb plug and is your controller a real PS3 Sony controller or one of those mad catz controller. If it is not the USB plug that came with the PS3 that could be one problem, if its not a real Sony PS3 controller that could be one and if your PS3 is less than 60gig dont play or watch any thing on it when you plug in the controller
    May 11, 2009 | Sony Playstation 3 (PS3) Console
    Stuck in USB mass storage mode.
    Try a master reset:
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200 series device:
    Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
    1. Start with the unit OFF and unplugged from power
    2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
    3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
    4. Release the power button when the device powers ON
      • You will see a new message: Do you really want to erase all user data?
    5. Remove your finger from the touchscreen when this message displays
    6. Touch Yes
    The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
    Mar 01, 2009 | Garmin nuvi 260W GPS Receiver
    Western Digital Passport 160 GB external HD won't load.
    WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
    "Problem:
    Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
    Cause:
    Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
    Resolution:
    This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
    Click on Start.
    Click on Control Panel.
    Double-click on the System Icon.
    Click on the Hardware Tab.
    Click on the Device Manager button.
    Click on the + next to Universal Serial Bus Controllers to expand the selection.
    Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
    Click on the Advanced Tab.
    Check the box that says: Don't tell me about USB errors."
    This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
    But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
    Feb 01, 2009 | Western Digital Passport 160GB External...
    Power Surge error message
    I guess that this could be your error message:
    "Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
    If it is the case, please try below solution:
    SYMPTOMS
    When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
    Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
    Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
    To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
    Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
    Close Device Manager.
    I hope that this should resolve the issue for you.
    Please let me know the result.
    you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
    I'll be glad to help you.
    Oct 18, 2007 | IBM ThinkPad T43 Notebook
    USB error message
    Have you connected any other USB devices to your PC? The USB ports can only supply a small amount of power and some devices especially USB connected hard drives consume more power than it can provide so they usually have an external power supply. Remove any other USB devices & try again. Did you have your camera connected before with a power adapter? Are you camera batteries fully charged? Let us know how you get on...
    Aug 09, 2007 | Fuji FinePix S3000 Digital Camera
    Sony Playstation 3 (PS3) Console Logo
    140 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
