Question about HP (153147-001) Sound Card
Which soundcard shoul;d i install for hp systems.How should i install.how to change bios setup
  • Anonymous Feb 24, 2009
    hi ,
    i eraised my sound drivers unfotunely in add or remove programmes now i am unable to get anykind of sound from my pc
  • 1,800 Answers
Install a creative sound card
sound blaster its a good one and supported with ur motherboard.
no bios changes keep it like it was
just install the driver of the sound card.
plz rate this post
Posted on Feb 22, 2009
I bought a new harddrive and my hp nc6220 still says setup did not find any hard disk installed in computer how to fix
You have to check on your bios in advance chipset by pressing F2 or DEL after pressing the power button then go to advance bios, whether it's AHCI or IDE. If its set on IDE change to AHCI by changing the values based on your bios setting for example F5/F6 or page up/page down, or change from native to enhance something like that. Then save the bios settings like F10 or Esc then press Y. Then try installing again your operating system.
Feb 26, 2015 | HP Compaq Nc6220 Laptop
I have a HP 630 laptop, if i make disk partition on it then I cant format/reinstal windows 7 on it. I have to delet all the partions and then reinstal windows 7. This has become a big problem for me as I...
Go into the Bios or Setup. When you press the power button look for the key that it says to hit to get into the Bios or System Setup. Hit that key. Look for AHCI in the bios and change the setting. Maybe set it to SATA or something, but change it. Then try reloading your operating system.
All you need to do is put the operating system disk in the drive and let it do the rest. It will delete the old partition and format the drive for you if you tell it to. Actually you just want one big contiguous partition which is the easiest way so if you have multiple partitions delete them and let it install into one big contiguous partition.
May 01, 2012 | HP Computers & Internet
I have hp dc7600 i having problem in sound...i installed sound drivers and in device manager ther is no quetion mark means sound driver has been installed but in control panel nd in sound speech and audio...
If you have a soundcard installed it may not be seated properly or if you are using the onboard sound it may be swiched off in the bios, in which case you will have restart the computer and push whatever button is posted on the screen to enter setup (usually F2, F1, ESC, or Delete) and make sur the onboard sound is enabled. The bios setup is a little different for every motherboard so I can't give you specifics but it usually isn't too hard to figure out.
Aug 17, 2011 | HP Compaq dc7600 PC Desktop
Installed new bios for windows 7, not working,on start up, computer locks up, able to unlock- but didn't happen with original bios. Looking for old bios to re install sholder012001@yahoo.com
o open the BIOS Setup screen: Reloading the BIOS default settings To reload the factory BIOS settings to the setup default:
  1. Press the F5 function key.
  2. Select Yes or OK.
  3. Press the Enter key.
  4. Press the F10 function key.
  5. Select Yes or OK to save the defaults.
You can also complete the following steps to reload the factory BIOS settings using the menu:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults.
  3. The system prompts you to load the optimized setup defaults. Select Yes or OK and press the Enter key.
  4. Select Exit Saving Changes.
  5. Press Esc and then press Enter to exit Setup.
Please don't forget to rate this if it fixed your problem. Four thumbs up is basically what means your problem was solved. Anything less means your problem was not solved. Not sure people here understand that as far as how we get rated.
Jan 15, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
Powering ensonic 1370 soundcard
I THINK THIS PROBLEM IS COMING FROM THE SMPS, I RECOMMEND FIRST YOU TO SEE THE BIOS VALUES IF YOUR DEVICE IS BEING DISPLAYED THEIR SO FROM THEIR YOU CAN CHANGE YOUR VALUES OF VOLTAGE OR IF THE DEVICE SETTINGS ARE NOT PRESENT IN THE BIOS SETTING THEN YOU COULD CHANGE YOU SMPS: THIS WILL SURELY GOING TO WORK.
Mar 23, 2010 | Dell HP-P2507FW Power Supply ** FREE...
E-MU 1616. Problem installing drivers
"I am running windows XP proffessional 5.1 on a HP (compaq) dc7600.
Could this be the problem?"
It could be. Bring up your system properties box (Windows key + Pause/Break key). Is that the version shown at the top right on the GENERAL tab?
Is there some reason you have not installed service pack 2 or 3? Of course if you're running an illegal copy of Windows you can't, but I mean any legitimate reason? If we can eliminate the problem with installing the latest service packs we can move forward.
Jun 17, 2009 | E-Mu 1616M Sound Card
I hear no sound in my pc
Are you using the same operating system? It seems the driver is incompatible with the operating system you are using. Try downloading the latest driver from the Intel support website.
One other option is to check if your onboard audio device is enabled in the BIOS. If it is not, the device won't be detected of course.
Jun 09, 2009 | Computers & Internet
How to do the CMOS setup in HP Compaq DC5100 SFF (PM215AV)
Common  keys are delete, f1, f2, f3 , f5 , f10 , escape and insert If these dont work, then check on Hp's page for your computer; you should be able to download a manual.
May 23, 2009 | HP Compaq dc5100 Small Form Factor PC...
Soundcard
Hey there, the HP bios is pretty smart - it should automatically detect a new sound card and switch off the internal one when installed - alternatively you can go to the 'system devices' panel and disable it in the software as well.
hope this helps
cheers
Nov 19, 2008 | HP Compaq dc7600 Convertible Minitower PC...
Sound
i need soundmax for my orange pc
Mar 27, 2008 | HP Compaq d220M (829160054797) PC Desktop
HP (153147-001) Sound Card Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
