Question about Toastmaster 1315 5-Quart
Little inline resistor does not pass current
The little resistor on the power cord does not pass any power to the cooker
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
I am tempted to suspect that it is not a resistor but rather a thermal fuse (thermal cut-off). Would it look like the image below?
If yes, then it would be readily available from most electronic components stores including Radio Shack.
Good luck and thank you for using FixYa.
Posted on Feb 22, 2009
Is the crock pot hamilton beach pot goes in the oven?
...You can Heat Or Cook a Roast Beef in your Hamilton Beach
Crockpot. Never use ANY of its Parts in a Regular Gas or Electric
Oven! Remember to Spray the inside of the Crockpot with a little PAM, before you cook, and add a little Water also...Not much...just a little; as foods will always Add their own juices.
Mar 02, 2015 | Hamilton Beach 33162 Stay or Go Stainless...
Can I replace cord on Corningware cooker.
Yes you should be able to replace this cord.
Start by a/ Getting the size of cord required, is it 1.5 or 2.5mm conductor size. Check the manufacturers rating plate to see wattage/power rating of the cooker.
b/ Check the cord, is it heat resisting type??
c/ Cut a piece off and take it to local diy electrical shop to get correct rating and type.
d/ ALWAYS SWITCH OFF BEFORE CHECKING ANYTHING.
Dec 01, 2014 | CorningWare Crock Pots & Slow Cookers
My cooks essentials technique pressure cooker will not turn on. It's like no power is reaching it. I've plugged it into outlets, but it won't turn on.
I had no power on my cepc800. Since parts are not available I had my husband tear it apart. If you are not electrically inclined don't try it....the problem in mine was a high temp resistor, which was bad. The problem was solved with a $2.50 resistor from our local electronics store.
May 21, 2012 | Select Brands Crock Pots & Slow Cookers
Lost power cord
SEND ME A PICTURE OF THE CONNECTION WHERE THE CORD PLUGS INTO THE COOKER,I COULD HAVE ONE,
Mar 18, 2012 | Wolfgang Puck Crock Pots & Slow Cookers
The electric cord plastic jacket melted and burned through wire on one spot. Can the cord be replaced
I am currently attempting to do that myself. You need to separate the liner from the outside part. Using a pair of pliers, loosen the round nuts (found on the bottom) holding the unit together & separate. You'll find that the unit won't come completely apart because of the wiring. There is a heating band, held together by a spring, around the inner liner. Remove the spring to release the band. This should allow you to remove the inner liner & give you access to the wiring. At this point, you'll need to clip the appliance cord by the little wire nuts. The hardest part will be getting the cord out; there is a strain relief grommet that holds the cord in place and prevents it from being cut by the sheet metal where the cord goes through. I broke this strain relief on my crockpot and am currently looking for a replacement. Once I find a cord relief, I should be able to reconnect the wiring, the heating band and assemble the unit. Be careful not to cut yourself on the sheet metal!
Nov 23, 2011 | GE 106661 4.5-Quart
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
West bend slow cooker model 84866 lost power cord, repl part on their site is 5.99 but 7.95 for shipping is ridiculous
I found this one on eBay but do not know if it will fit your machine. It is a little less expensive and is used. Replacement parts are always expensive but less than buying a whole new machine...much less it keeps it out of the landfills. http://cgi.ebay.com/VINTAGE-WEST-BEND-SLOW-SLO-COOKER-REPLACEMENT-CORD_W0QQitemZ320494123773QQcmdZViewItemQQptZSmall_Kitchen_Appliances_US?hash=item4a9ef03afd
Feb 20, 2010 | West Bend 84866 6-Quart Slow Cooker
Lost power cord to my wolfgang puck 5-Quart Pressure Cooker
I believe the power cord is just like the power cord to a desktop computer. You can buy one at Best Buy
Apr 20, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
West Bend slow cooker
There is a website that carries cords for "All Round 4qt. Cookers" Price $3.99 from Focus Electrics.
The link is below:
http//www.focuselectrics.com/catalog.cfm?dest=dir&linkid=101&linkon=catagory
Oct 15, 2008 | West Bend Crock Pots & Slow Cookers
Toastmaster 1315 5-Quart Logo
60 people viewed this question
Top Toastmaster Crock Pots & Slow Cookers Experts
charles
Tom Chichester
Brad Corbett
Brad Corbett
Level 1 Expert
Are you a Toastmaster Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
