Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Can not use washer it displays control locked
    President:
  • Whirlpool Master
  • 2,651 Answers
Htere should be a button marked "control lock" on the far right of the control panel hold in for 3- secs
Posted on Mar 02, 2009
Washer kenmore elite washer model 417.41102000 displays LOC and won't turn on. how to reset and unlock the controls?
Control Lock (Press & Hold) To lock the controls between or during cycles, press and hold the Add Steam button for 5 seconds. ' will be displayed if you attempt to wake up a "between cycle" locked unit and ' will alternate with cycle time remaining in a "during cycle" locked unit. Repeat to unlock the controls when you are ready to operate the washer. Use this feature to reduce the likelihood of accidental operation by children. 41741102000 KENMORE ELITE WASHER Manual Sears PartsDirect
Hope this helps?
Mar 29, 2016 | Kenmore Washing Machines
It displays 'control lock' with red light
Here are a few Different models as i do not know yours.
How to Unlock the Control on Whirlpool Duet eHow
Maytag - To unlock the controls, press and hold the CYCLE END SIGNAL for 3 deliberate seconds or until the control lock light goes out. If the control locked light will not turn off, I recommend unplugging the washer for 5 minutes. Plug the unit back in and see if the controls will respond. If not, I recommend calling a service technician to diagnose and repair the washer. You could have a failed control console or a bad electronic control board in the washer.
Kemmore- Unplug for 10 minutes.
GE washer - Make sure that the control for the washer is not locked. If it is, press and hold the LOCK button for 3 deliberate seconds (or until the control unlocks).
There is not another way to reset the control board other than completely unplugging the washer as you have been doing. Since the display light up and works, the washer apparently has electrical power supplied to the control board and control console. You could have a failure in the console that is preventing the start button from working. A failed control board or a problem with the door switch could also prevent the washer from starting. Make sure that the washer door is firmly closed.
If the washer will not start after checking the control lock and the door, I recommend calling a service technician to diagnose and repair the washer.
Good luck More info would be helpful. Make and model. Is always a plus.
Oct 02, 2014 | Washing Machines
Error message LOC
Do the following:
The Control Lock (child lock) is on: To prevent accidental operation of the washer or alteration of the cycle settings, press and hold the lock symbol until you hear 3 beeps and LOC is displayed. To cancel, press and hold the lock symbol until LOC is no longer displayed. To put the control into control lock you do the same thing.
God bless you
Sep 26, 2012 | Frigidaire ATF6000ES Front Load Washer
My washer is loc and I don't know how to unloc it
The Control Lock (child lock) is on: To prevent accidental operation of the washer or alteration of the cycle settings, press and hold the lock symbol until you hear 3 beeps and ?LOC? is displayed.
To cancel, press and hold the lock symbol until ?LOC? is no longer displayed. To put the control into control lock you do the same thing.
Jul 30, 2011 | Frigidaire Washing Machines
Hi; Our washer displays "Control Panel
jazzbassic,
On the front of the unit is a control lock button, you will need to push and hold that button unit the control panel is unlocked. This should solve this problem. PS you may have pushed the control lock button when you either attempted to open door or just learned on panel, either way this does happen from time to time.
Jul 11, 2011 | KitchenAid KHWS01PMT Front Load Washer
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
Jun 28, 2011 | General Electric WCVH6800J Front Load...
How to resolve door lock problem
Is this a door latch problem that is being displayed on the control panel? Is the door mechanism broken? Is the door latch working, but is jammed and will not open? Is this a control panel lock problem, where the washer is locked and will not operate? There are several different causes of door latch problems.
If you are experiencing problems with the door locking, or if the washer is displaying and error code of "Fdl" or "Fdu", the door latch commonly needs replaced. The following link explains how:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
If this is a matter of a door jam and you cannot open the washer, there is a manual release you can use to open the door. The following link explains:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
If this is a Control Lock issue where the control panel is locked and you cannot use the washer, the following link explains how to turn the feature on/off:
http://www.fixya.com/support/r3608801-control_panel_lock
If you have any questions, please post back and let me know. I hope this information is helpful to you.
Jan 07, 2010 | Kenmore Elite 45986 Front Load Washer
LE message, will not lock the door - Daewoo front load
Hello there:
This is a fairly common problem with these newer machines Here are the 2 most common fault codes on these machines I have listed below this post.
If the machine is still under warranty i would suggest using it normally they will repair this for free
and some of these have a recall on these machines
so i would contact the appliance center where you got this from and see if you can get it repaired ok?
"LE " persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board. 1E persists in washer display Lid lock failure Replace lid lock switch or control board.
Dec 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore HE washer displays DL failure code-what can we do to trouble shoot before calling a home repair? This is actually a 45088 if that makes a difference
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Ohm out the door lock solenoid and the door lock switches. This is most conveniently done at the central control board--use the wiring diagram/tech sheet to locate the proper pins to test from. Unplug the washer before starting work.
hope this helps....
Oct 24, 2009 | Kenmore 45087 Front Load Washer
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
