Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My Epson Stylus DX5000 won't work. All the lights are flashing and my comouter tells me to open it up and remove the "foreign" object. I can't see any foreign object and can't see hoe t open it up other than just lift the top to access the printer cartridges. Everything seems to be clear down there but I get the error almost immediately on powering up. Any ideas? Thanks, Norman Wilson
  • devenneyseli Apr 15, 2009
    WHEN I TUR ON THE DX5000 ALL THE LIGHTS START FLASHING AND THE PRINTER JUST WONT DO ANYTHING IVE TRIED RESETTING INK COUNTERS BUT THE LIGHTS STILL FLASH..
I had the same problem and checked for paper jam but wasnt any so i kept turning on the printer while looking in side and found that one of the little white cogs where the ink box rests wasnt catching when i pushed it into place the printer set itself and started working maybe you could try this. good luck.
Posted on Apr 16, 2009
  • 24 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
asd-5
Posted on Sep 03, 2009
I'm using an emachine pc and when i press the print button to send my images to the dx5000 nothing happens-even though everything sems to be okay with the printer,it just won't print any images.
Posted on Jun 17, 2009
  • Epson Master
  • 541 Answers
Go on to this link and you will get the resetter for your printer My Epson Stylus DX5000 won't work. - moz-screenshot.jpg
moz-screenshot-1.jpghttp://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Posted on Feb 22, 2009
All light flashing on epson stylus sx105
Epson Stylus Printers all lights flashing 1160 760 860 etc ..
just found this for you not saying it will work for your printer but give it a try.
Nov 22, 2016 | Epson Office Equipment & Supplies
All lights flash on Epson stylus TX110
switch off the main power of printer in running situation and then on the printer.. hope it will be work..
Aug 20, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. for epson stylus r 290
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on.
Feb 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
Two red lights flashing, but i can't figure out what's wrong
According to the documentation for your printer.
Red probsolv.6.3.11.jpg paper and probsolv.6.3.12.jpg ink lights flash alternately Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, contact your dealer or Epson as described in Where To Get Help.
Dec 16, 2010 | Epson Stylus C86 InkJet Printer
I have an Epson Printe RX 420 and now an E has appeared while the green lights go on and off. What to do? many thanks, Yvano
power off printer.check for obstructions/foreign objects. remove obstructions/foreign objects. power on printer.
Jul 06, 2010 | Epson Stylus RX425 Multifunction...
When the Epson C87 stylus printer is about to print, it makes a high pitched scream and doesn't print. The 2 left hand red lights flash quickly and simultaneously and the green light does not show. The...
Hi
I think maybe it could be that your ink cartages are slipped on the thin belt that moves them from one side to another or it stuck or belt come off take a look and see it the ink will slid from side to side you can do this by hand but don’t push them to hard, that what it sounds like to me it worth a try.
All Best: Pineworks
Jan 24, 2010 | Epson Stylus photo C87 InkJet Printer
Can't open Epson DX5000 to remove object stuck inside
sounds a little draconian, but sometimes if you invert th peinter and give it a tap, the foreign object may fall out. Just don't leave it upside down too long!
Dec 15, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
2,264 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
