Question about Kenmore Dryers
Intermittent heat from dryer. We have a stacking washer/dryer. The dryer (over the last few months) only heats up some of the time. When we monitored more carefully yesterday, it seems like sometimes, the heat comes on at the beginning of the cycle (we can see the pilot come on and the glow of the element), but some point later, the heat turns off for the remainder of the cycle. If we stop the dryer after the heat turns off and restart it, sometimes the heat will turn on initially. Sometimes, the dryer starts/restarts without the heat ever coming on. So is this a problem with the thermostat?? If so, is this easy to replace? So far, we've only removed a small panel at the rear right of the dryer to be able to see inside the dryer, and we can see that the pilot/element area is at the front left of the dryer. No idea where the thermostat is. Thanks for any help!
Bgillespie
  • 89 Answers
SOURCE: Kenmore 90 Plus Series Electric Dryer trip
It sounds like the motor switch which is actually inside the motor on the model. It is very expensive to replace motor so it may not be worth fixing......
Although I stick to the above statement; I have seen cases where a thermal fuse wire has come loose and perhaps sometimes touching(allowing heat) and sometimes not(hitting something blowing the breaker.... Check all wires on blower vent area... GOODLUCK!!!
Posted on Dec 17, 2007
Amigaman
  • 248 Answers
SOURCE: Dryer does not heat up and now wont start!
Recheck for 220 at plug. May have tripped breaker.
PULL PLUG FIRST!!
Remove rear panel. Check for continuity at white thermal fuse located near bottom center on the blower housing. It should close to 0 resistance. Also check hi-limits on side of heater housing. Also should be close to 0 resistance. If any are open, replace and clear venting. Also remove 4 screws on bottom of filter housing and pull bottom of housing out. Reach in and remove lint.
Posted on Nov 15, 2007
jsrock516
  • 5911 Answers
SOURCE: Heating element
The model number you provided suggests that the lint screen is on top of the dryer, right? If so, the heating element can be accessed from behind the dryer by removing the rear panel. Of course, you should know this already since you stated you've already replaced the thermostat and fuse. The heating element is located on the right-hand side as you are looking at the dryer from the rear. There are TWO components on the heater housing. One is the high limit thermostat, one is a thermal cut-out. Are these the components you mentioned replacing? BOTH should read a short (0 ohms) when measuring resistance with the dryer turned off. If you haven't replaced both of them, double check to see if they are both good. The high limit thermostat will be located closest to the ceramic heater connection. The thermal cut-out will be mounted to the heater box. Perform a resistance check of the heating element as well. Measure across the leads of the heating element at the ceramic terminal connection. It should read between 8 - 13 ohms if good. If your readings prove that the heater is bad, it can be removed by using a 5/16" hex drive. The heating element should slide out the bottom of the heater box housing. Sometimes removing the heater box, and then removing the heating element is easier.
Your dryer is also equipped with an electronic cycle control board under the control panel that goes bad from time to time. This also may affect the dryer heating circuits. Inspect the small circuit board for any obvious signs of burned components.
I hope this information is helpful to you. If I'm wrong about your dryer configuration, please post back with comments, so I can give you proper instructions.
CAUTION: Make sure you UNPLUG the dryer prior to making any resistance checks. Dangerous voltages are still present with the dryer turned off.
PS I hope I'm not insulting your intelligence, here. As a rule, I tell everyone this information because some are not as savvy as others.
Posted on Feb 24, 2008
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
SOURCE: kenmore dryer. 80 series. 6 years old.
Sounds like there is dirt and or lint in the fire eye that is used to keep the gas on. Find that, clean it, and try again.
Posted on Apr 27, 2008
Frigidaire model fex831cso serial xe34800123
Hello friend, we appreciate your post!
It appears you have a laundry center FEX831CS0 and that your dryer is not working. Can you provide me more specific details? Is your dryer not heating, not turning on, or not completing a cycle? For instance did you notice any strange functions or odd noises prior to this issue? With this information I can better address the issue at hand. Thank you - Matt
Jul 19, 2014 | Frigidaire FEX831CS Top Load Stacked...
Dryer works, but no heat.
Thermostats/thermal-fuses in back of dryer, usaully 2 of them, call a local appliance supply place, should be able to supply them. if electric 220volt, 1 side is 110v for heat otherside 110v is the motor, timer, light, ect.
May 23, 2012 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool stacked washer/dryer won't heat
Check your wiring connections, then check your upper limit thermostat for continuity with an ohm meter this unit should show short when cold, open when to hot. It will be located near the heating coil assembly.
Apr 16, 2012 | Washing Machines
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore washer/dryer combo
I Can give you a few things to check if your mechanically inclined, but if you dont feel comfortable digging into the machine I would suggest a technician visit..   if you feel like digging into it send me an email at bigtexan1000@yahoo.com and we can begin
May 30, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Nov 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Stackable Washer will not drain.
check if there is a low humming noise when on drain. if so there may be a foreign object trapped in pump. otherwise have you checked filter?
Apr 02, 2007 | Whirlpool LTG6234D Front Load Stacked...
Dryers Logo
354 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
