Question about Sharp AR-5316 Advanced Digital Imager Copier
I can't use Print function for ByPass or Document Feeder?
I have an ARs-168 Sharp Digital Imager - I want to print (not copy, but PRINT) on Resume Stationery paper, but I can't use either the Document Feeder or the By-Pass tray.  Of what use are these two feeders if I can't print from them?  I can only COPY from them? I'm not sure which it is gray scale or all-in-one (it has scan, fax, print, copy)
  • Vl Towler
    Vl Towler Feb 27, 2009
    Thank you for spelling it out to me.  I understand now.  I will print out your answer and tape it to the copier! Thank you, Marcus!
  • 37 Answers
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Posted on Feb 27, 2009
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Print or copy at A3
you will ahve to set this in the print properties when you select print on the file option go to paper and select bypass if you are using this tray and original size will be A4 print size will have to be set to A3
May 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
When copy a document, it will scan but the print out page is blank. I tried replacing the toner but got the same problem. The unit is still 3 months old so i think the drum is still ok.
I know it sounds simple, but do you notice the scanner light on? Open the cover and try a "sky shot." The copier should print out a black page. You'll also see whether or not the light is on and the scanner is moving.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP MX-2300N
Someone has sent a print job from a computer to the copier with an odd paper size specified. Go to Job status, under "print" highlight the first job in the que and delete it. (if the job was sent more than once you will have to repeat. ) Check the document and print settings of the offending document.
Dec 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp fax printing problem
Curfman.....your scanner has gone bad
kireeti....open the document feeder and check for obstructions or a switch actuator stuck down.
Jul 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Document jam
There is most likely a very small piece of paper in the document feeder.
What you can do is take a minella folder or some card stock, open the document feeder cover and shove the folder or card stock through the feeder to dislodge whatever is stuck in there.
The document sensor itself may be knocked out of position.
It can't be the copy paper path since you can print.
May 16, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Canon service 6000
Well... here it is :
The POWER Lamp Flashes Orange title-bar.gif An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
When a printer error occurs, the POWER lamp flashes. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error.
bullet.gif Two flashes: Printer is out of paper /Paper does not feed
Reload paper to the sheet feeder or cassette and press the RESUME button.
bullet.gif Three flashes: Paper jam/Paper output tray is closed
If paper is jammed, remove the jammed paper, reload paper in the printer, and then press the RESUME button. If the paper output tray is closed, open it.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
Press the RESUME button to resume printing with an empty ink tank. Replace it with a new ink tank immediately after the printing. It may damage the printer if you continue printing with an empty ink tank.
bullet.gif Five flashes: Print head not installed/Print head not installed correctly/Print head is defective
Install the Print Head. If the Print Head is already installed, remove the Print Head and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact a Canon service representative.
bullet.gif Six flashes: Inner cover error
To print on paper:
Close the inner cover. Then press the RESUME button to start printing.
Do not move or close the inner cover during printing. It may damage the printer.
bullet.gif Seven flashes: The CD-R or DVD-R is not set on the CD-R tray
Reset the CD-R tray feeder with a CD-R tray containing a CD-R or DVD-R, and then press the RESUME button. Printing will resume.
This function only works with models that support CD-R printing.
bullet.gif Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during print head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible.
bullet.gif Nine flashes: A specified period of time has lapsed without receiving no response from the digital camera / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME button and reconnect the cable.
If the error is still not solved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use a digital camera or digital video camcorder compatible with this printer.
bullet.gif Ten Flashes: Cannot print on both sides of the page
The size of paper may not be compatible with automatic duplex printing. For information on the size of paper compatible with auto duplex printing, see "Automatically Printing on Both Sides of the Page." Pressing the RESUME button will discharge the paper, and restart printing from the front side of the next paper. The reverse side will not be printed when an error occurs.
bullet.gif Eleven flashes: Cannot perform automatic print head alignment correctly
bullet_s.gif A4 or Letter-sized paper is not loaded on the sheet feeder.
bullet_s.gif Ink has run out or ink tanks are not installed correctly.
See Ensure that the ink tank is installed properly.
bullet_s.gif Ink level is low.
bullet_s.gif Print Head nozzles are clogged.
Press the RESUME button.
bullet_s.gif The paper output slot has been exposed to a strong light source preventing correct print head alignment.
Press the RESUME button to resolve the error. Align the printer so the paper output slot will not be exposed directly to a strong light source.
After carrying out the above measures, if the problem continues after aligning the print head again, press the RESUME button to resolve the error, and then perform manual print head alignment. For details on manual print head alignment, see "Aligning the Print Head."
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it for a while.
If the problem remains, contact a Canon service representative.
Apr 21, 2008 | Canon PIXMA iP1600 Printer
Problem Printing Lables from ByPass Feed
hello, can you check the settings on your printer in the menu functions, and also in the advanced properties of windows... good luck ;-)
Feb 19, 2008 | Panasonic WORKiO DP-C262 Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
314 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
