Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
How does the minn kota 65 all terrain run on 24
How does the minn kota 65 all terrain run on 24 volt system? or is it suppose to run on the 12 volt system only ?
  • Jim London
    Jim London May 11, 2010
    Hi, The 65 has a couple of different versions, The V2 is a 24Volt. But some of the older ones are 12 volt. See if you have more info on exactly which model you have.
My minn kota want run, battery charged any suggestions. thanks
Posted on Jul 09, 2012
    Problem Solver:
  • 8 Answers
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Posted on Sep 07, 2009
  • Ricky DeBats
    Ricky DeBats Dec 26, 2010
    what you refer to as jumped out. is in fact putting the batteries in series to get 24 volts as apposed to putting two 12 volt batteries in paralell which will give you only 12 volts but twice the capacity
Will a 12 volt lawn and garden battery run my 24 lb thrust minn kotta
Yes but not for long. You need to buy a deep cycle battery. Regards Phil.
Nov 18, 2012 | Minn Kota Endura 30 Freshwater Transom...
Lookinf for a manual for a minn kota model 55d
call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
No power like it is running on 12 volts need to know how to wire for 24 volts
I would first put a voltage tester on there and see if your getting 12 or 24 volts... You could have bad batteries... As far as running a 24 volt system the best thing to do is to set it up based on the owners manual... My 24v system has the position from battery (1) one going to the motor (put a fuse on that thing), the negative on battery (1) one goes to the position on battery (2) two. The negative on battery (2) two goes back to the motor.
Feb 27, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Possible sticking foot control switch
If you can undo the switch and it won't run any more, the it is the switch except for any other wiring short out of sight depending how that switch is hooked up. Strangely these devices should be designed to fail to safe. In your case some exception?
Apr 28, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn kota 65
open up the prop area and look for / remove corrosion
Apr 06, 2008 | Minn Kota 55 PowerDrive Motor/Sonar Combo...
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
1,010 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
