Question about Sony KP-61HS10 61" Rear Projection Television
Where is the convergence baord ( amps ) locketed ? what is looklike?
  • nicksanghani Mar 02, 2009
    thanks for help.
  • Sony Master
  • 3,459 Answers
Buy a repair kit from www.TvRepairKits.com . They have a photo repair guide that will show you every step to fix the tv. The kits also include the parts.
Posted on Feb 28, 2009
What RCA JACK MEAN &LOOKLIKE
RCA jack is also known as Phono connections!
Hope this helps!
Nov 02, 2014 | Televison & Video
I forgot my motherbord name & serial no. how i get it
open your case you will find both on your motherboard name & serial no
cahck on center of mother baord you will find your Motherboard name and S/N
Apr 23, 2010 | Intel D845GVSR Motherboard
I can't find the IAC valve in my 97 ford expidition 4.6l v8, & I don't know what it's looklike either! can anyone be of help? Tnx a lots!!
first of all i do not know but give these websites a try www.autozone.com and www.alldatadiy.com if all fails stop by your local Ford dealership in the parts department and they be able to print you off pictures and diagrams showing you where it goes and what it look like wish you the best of luck Michigan Man
Nov 27, 2009 | 1997 Ford Expedition
PT53wx53g. green & blue convergence don't respond
You may need to check the two small resistors on the front of the baord as well. They are the power connections to you Convergence IC's, I have seen these charred and open. Just check them with a DVM or an Ohm meter to see what value they read. If they are close to 2 Ohms they most likely will be OK. But the other blue resistors will need to be replaced if they do not measure around 2.2 Ohms.
Please rate both solutions, as we are here to help you with the most information that you can get.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 04, 2009 | Televison & Video
2007 Pontiac G6 winter tires
Yes you need sensors in any wheel you put on...what is a locket?
Oct 21, 2008 | 2007 Pontiac G6 GT Convertible
Convergence won't show up in menu
The convergence power supply baord has taken out fuse FL231 thats what causes the convergence option to disappear fromthe menu.
Aug 11, 2008 | Televison & Video
Convergence
Okay thats the P51A chassis that should have a small PC board on the extreme right hand side with two large black ICs mounted onto a large aluminum heat sink. they should be stamped with STK392-040 on them. can you locate the board on the right? Does it have the two large heat sinks on the baord?
Jun 07, 2008 | Televison & Video
Mitsubishi ws 46807 convergence
convergence fail. try resoldering the 2 convergence ICs in the middle baord located on the large heatsink. this might fix unless the problem has gone it course
Mar 21, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Double vision
Feb 21, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
102 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
