Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Windows XP. I have inadvertently removed the
Windows XP. I have inadvertently removed the Realtekaudio97 device. Is it possible to reinstall it. How please. I have tried but nothing seems to be available.
JL
  • Thomas F. Schneider May 11, 2010
    Here is their website link. See if it is availlable after you math up your card.( Yes; It is only software,and shoud be able to bvbe reinstalled)
  • 447 Answers
Your drivers can be downloaded from here. Simply reinstall and reboot. Good luck!
Posted on Feb 22, 2009
  • John Elliott
    John Elliott Feb 25, 2009
    You've provided no information as to the problem you experienced while reinstalling your drivers. The AC97 drivers are fairly generic (they're in a high percentage of todays PCs and laptops). You can do a google search on either AC97 drivers or AC97 HD drivers and download them. If you are receiving an error please post it here so that we may assist.
How to reinstall windows xp thinkpad x41
How to Reload Windows XP Without Removing Files Deleting system files, modifying the registry and installing incompatible drivers to Windows XP can damage the integrity of the operating system, rendering it inoperable. Virus infections are often responsible for making the aforementioned changes to a system, but employees who have administrative access to the workstation can make deleterious modifications to the OS as well. Reinstalling Windows XP can repair the OS, but if work-related files are stored to the system partition, all of the data will be erased during the installation process. To reload Windows XP without losing files, you can perform an in-place upgrade, also known as a repair installation.
Step 1
Insert the Windows XP CD into the optical drive and then press "Ctrl-Alt-Del" to restart the computer. Step 2Press any key when prompted to load the contents of the disc. Press "Enter" on the Welcome to Setup screen.
Step 3 Read the license agreement, pressing "PgDn" to scroll down the page. Press "F8" to agree to the terms. The CD will search for previous installations of Windows XP. Step 4
Press "R" to repair the selected operating system. The disc will begin reinstalling the operating system to the hard drive without affecting personal files. Follow the on-screen prompts to complete the repair installation. Step 5
Log in to Windows XP and sign on to the Internet when installation completes. Click "Start," "All Programs" and then "Windows Update." Step 6
Click "Scan for Updates" to search for applicable service packs and hotfixes to reinstall to the OS. Step 7
Click "Install Now" to bring the in-place upgrade up-to-date.
Things Needed
  • Windows XP CD
Tip
  • Make sure you have your Windows XP product key (found on the CD cover or on the computer case) available prior to reinstallation.
Warnings
  • If possible, back up your files previous to the installation in case something goes awry during the process.
  • You will need to reinstall all non-native programs and removable devices after performing an in-place upgrade.
Apr 27, 2014 | Lenovo ThinkPad X41 Tablet PC
I have SandDisk S3 UCL Mode USB Device which is not detecting right now. One week back its working fine. In computer management i found device has in diabled mode. when i try to make it enable its again...
How to Fix a Code 22 Error
  1. Enable the device. Since the most common reason you'll see a Code 22 error in Device Manager is because the device has been manually disabled, try manually enabling it.
    Most of the time this will fix a Code 22 issue. Don't worry if it doesn't, however. All that means is that the Code 22 you're seeing was caused by something a bit less common.
  1. Restart your computer if you haven't already.
    There's always the chance that the error Code 22 you're seeing on a device was caused by a temporary problem with the hardware. If so, a restart of your computer might be all you need to fix the Code 22 error.
  2. Did you install a device or make a change in Device Manager just before the Code 22 error appeared? If so, it's highly likely that the change you made caused the Code 22 error.
    Undo the change if you can, restart your PC, and then check again for the Code 22 error.
    Depending on the changes you made, some solutions might include:
  1. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is one possible solution to a Code 22 error.
    Important: If a USB device is generating the Code 22 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
  2. Update the drivers for the device. It's also possible that installing the latest drivers for the device could correct the Code 22 error.
    If updating the drivers does remove the Code 22 error, it means that the stored Windows drivers you reinstalled in the previous step were either damaged or were the wrong drivers.
  3. Clear CMOS. If Windows had to disable the device, generating the Code 22 error due to a lack of system resources, clearing CMOS might fix the problem.
  4. Update BIOS. Another possibility is that a newer BIOS version could better pass system resource handling to Windows, correcting the Code 22 error.
  1. Move the device to a different expansion slot on the motherboard, assuming of course that the piece of hardware with the Code 22 error is an expansion card of some kind.
    If the Code 22 error is due to a lack of system resources available for the card, moving it to a different slot on the motherboard could clear up the problem. This isn't as common a situation with newer hardware and Windows versions but it is possible and is an easy troubleshooting step to try.
  2. Replace the hardware. A problem with the device itself might be the root cause of the Code 22 error, in which case replacing the hardware is the next logical step.
    While not likely, another possibility is that the device is incompatible with your version of Windows. You can always check the Windows HCL to be sure.
    Note: If you're positive that the hardware is working properly and is properly configured then you might consider a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either before you replace the hardware, but you may have to give them a try if you're out of other options.
Please let me know if you've fixed a Code 22 error in a way I haven't mentioned above. I'd like to keep this page as accurate as possible.
What Does the Code 22 Error Apply to?
The Code 22 error could apply to any hardware device managed by Device Manager.
Any of Microsoft's operating systems could experience a Code 22 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 22 Issues in Device Manager?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more.
Be sure to let me know that the exact error you're receiving is the Code 22 error in Device Manager. Also, please let us know what steps you've already taken to try to fix the problem.
Show Full Article
Aug 03, 2017 | Computers & Internet
Just reinstalled windows xp and now my creative labs soundblaster live! audio card is not detected. did all the troubleshooting in the hardware manager and it says the the device is working properly. did...
You could have a ghost device in the system. Remove the card and start the computer in safe mode. Look at the device manager to see if there are any sound devices detected. If so, delete them. Now install the card and let Windows detect it. You probably left the card in the machine when reinstalling the O/S. You shouldn't have any peripheral devices hooked up when doing a reinstall of Windows XP.
Sep 26, 2010 | Creative Labs Sound Blaster Live! 5.1...
Acer Aspire 5100 will not boot from ****
The best way to handle this is to completely reformat the drive again, to rid win 7 and the bad XP, and to then re-install XP from the DVD all anew. Any other way is just going to cause hassles trust me.
Jan 27, 2010 | Acer Aspire 5100 Notebook
{HELP!!}} Inadvertently removed midi sound
A simple fix here. Perform a system restore.
There are a couple of way to do this: Click on the start menu and then click on run, in the box type rstrui.exe and press enter. Or you should find system restore in All programs, accessories, system tools and system restore should be there.
Once you have the system restore window up click on restore my computer to an earlier time and take the computer back to a time before you deleted/uninstalled the programs.
Good luck.
Dec 04, 2009 | Microsoft Windows XP Professional
How to break log-on password
MS Support says you must have a password reset disc or XP will need to be reinstalled. http://support.microsoft.com/kb/321305
There are some tools you could obtain from various online outfits that can recover the password. Google "How to recover logon password". Several will pop up.
Oct 04, 2009 | Microsoft Windows XP Professional With...
No audio device on xp pro..???????
Open up Device Manager, right-click on the computer name at the top of the hierarchy and select Scan for hardware changes. It should re-detect your hardware in reinstall the proper drivers.
Jul 10, 2009 | Microsoft Windows XP Professional
Window 98 Professional does recognize Panasonic RR-US395 since it was removed from the usb port accidentally before being removed properly. I can see that the recorder is connected but can't find the files...
Windows 98 Professional?
I don't think there is such a version. It's probably either Windows 98 or Windows XP Professional.
If a reboot does not help, the simplest thing to try is to reinstall the device driver registry entries for the USB port.
Assuming you have Windows XP, right-click "My Computer" and select "Manage". Under "System Tools", select "Device Manager". If Windows is detecting problems with any of the device drivers, the Device Manager entry will be flagged with a exclamation point caution sign. Otherwise, you can try removing all of the entries under "Universal Serial Bus controllers". To remove the entry, right-click it and select "Uninstall". Remember, this only removes the entry from the registry. Unless the drivers are corrupted or missing, you will likely not need the install disk to reinstall the entry. Once you are done, reboot and Windows will detect the USB controller(s) does not have an entry and will prompt you to reinstall it. Take the option to let Windows find the drivers for you. If this procedure does not work, try uninstalling and reinstalling the drivers for the device. If that does not work, you likely have a hardware problem - bad cable, bad connection, etc.
If you do indeed have Windows 98, it's been a while, but the above procedure should be similar.
Jun 12, 2009 | Panasonic RR-US395 Digital Voice Recorder
Default Mail Client has been deleted from my computer
In WIndows XP, you can sent your default mail client through the Internet Options settings in Control Panel under the tab 'Programs'.
Typically, this is set to Outlook Express or Outlook, but you may also use a third party software program like Mozilla's Thunderbird.
Hope this helps!
Mar 31, 2009 | Microsoft Windows XP Professional
No audio device
Hi, just Google the MSI website, click on download and support,
Locate your board and click the link for downloads for it. You will find Audio drivers listed there. With MSI it is usualy Realtekaudio97.
Regards mistyman
Oct 12, 2007 | Creative Labs Sound Blaster Live! 5.1...
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
49 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
