Question about Sharp Video Cameras
MY OLD SHARP SLIMCAM VHS CAMCORDER DOOR THAT YOU PUT VHS TAP IN DOSE NOT CLOSE LIKE IT DID WON'T RUN BECAUSE DOOR WON'T LATCH I HADE IT WORKING A FEW MINUTES, BUT WHEN I PUSH THE EJECT BUTTON, DOOR WOULD NOT SHUT AGAIN CAN'T FINDE MY MANUAL MODEL NO.VL-L64U
I have a question? I haven't used it in years. I charged the battery and attached it and it won't come on. No light comes on, it won't do anything. What could be the problem(s).
Posted on Jun 30, 2013
  • 64 Answers
SOURCE: Sharp camcorder vl-wd450
something is wrong with the m-chassis needs repair sorry the chassis on any cameras are very sensitive and they break alot not yor fault.
Posted on Nov 19, 2007
SOURCE: driver
send me driver for it
Posted on May 02, 2008
SOURCE: Driver for Sharp VL-Z5 Mini DV Digital Camcorder
Try this
http://www.sharpusa.com/products/TypeSoftware/0,1086,47,00.html
Posted on Jun 28, 2008
SOURCE: SHARP SLIMCAM VL-L624
it records in color but the little screen is black and whit
Posted on Jul 08, 2008
mediarich
  • 188 Answers
SOURCE: Hooking up T.V. to my camcorder
Does your TV have an input which would be lited as Video 1?
There should be video and audio outputs from the camcorder and if you have video and audio inputs to your TV you just need a cable and the capability to view it on your TV. If you don't have audio and video inputs to your TV you should check out the sales at the local electronics store. I hope this helps.
Posted on Dec 12, 2008
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Not heating
If the door sensor thinks the door is ajar, it prevents the microwave from heating as a safety precaution.
I found with my old microwave that tapping on the closed door, right at the latch, with a little bit of force would convince the sensor the door was really closed.
Apr 11, 2008 | Sharp R-930AK Convection/Microwave Oven
Door won't lock
If your dishwasher door won't lock, it could be a problem with the latch adjustment or the door seal. Some latches are designed to be adjustable, and yours may be set too tightly. Look at the owner's manual for specific instructions or follow these basic steps for adjusting the latch:
1. Spray WD-40 or other lubricant onto the latch.
2. Slowly open and close the door several times, noticing whether the door hits the strike plate (the metal plate on the top of the dishwasher frame). Use a hammer to lightly tap the strike plate to move it as needed.
3. If possible, adjust the depth of your latch by unscrewing the latch assembly using a screwdriver and reseating it. Work with the adjustment until it latches correctly.
Note: If your latch is permanently fixed, have a qualified professional address the problem.
The door seal-also called a gasket-can also cause problems if you have a brand new dishwasher or door seal. The good news is that the door seal will mold to the door's shape over the first week or so. Operating your dishwasher with the highest level of heat will help this process happen more quickly. Because the material is pliable, and because heat will soften it, it will seal to the door more securely after those first few loads.
On the flip side, an old door seal can also keep your door from closing correctly. Check the seal for signs of warping or damage. If the seal needs replacing, arrange for service, or consider doing it yourself. In most models, it's a relatively easy DIY project. See Dishwasher gasket replacement for step-by-step instructions.
For more troubleshooting steps, see Dishwasher door repair. I hope this helps!
Oct 08, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
Sharp camcorder VL-L285 Troubleshoot
Any VHS camcorder is probably at the end of its life by now - replace it with something more modern
Jun 03, 2017 | Sharp Video Cameras
Tape door won't close i get error message reattach power. i've reset , used different power supply, still tape door won't close any goo ideas? chuck
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
Sep 12, 2011 | Sony Handycam DCR-HC96 Mini DV Digital...
Camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Dec 27, 2009 | RCA CC6363 Camcorder
Interior light stays on,dash board minder says door is open it's not how do i get to the switch
courtesy light switches are located at the door latch,try a good dose of WD40 or equivalent sprayed into latch on door .open & close a few times .....check wiring & switch
Oct 03, 2009 | 2003 Ford F250 Super Duty Crew Cab
Mar 17, 2008 | Video Cameras
Video Cameras Logo
236 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
