Question about Acer Aspire 4315-2490 Notebook
Disable touchpad I have a acer aspire 4315-2490 notebook running vista home edition and have installed a usb mouse but now the touchpad gets in the way of typing. have look for a way to disable but cannot find does anyone know how ?
    President:
  • 1,902 Answers
Click start, ccontrol panel, right click mouse, click on properties and disable. If that does not work then try updating that driver. If it still does not work then go to MSCONFIG and disable it on startup and this will disable it permentaly
Posted on Feb 22, 2009
  • 741 Answers
You can get to it by clicking on Control Panel>Hardware and Sound>Mouse>Hardware Tab then click on TouchPad>Properties>Change Settings.
Dell computers do not allow you to disable the touchpad for some reason. Hopefully Acer is a little more flexible. Good Luck. Let me know if you have any problems.
Rate this with four diamonds before logging out.
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
I cannot get my mouse curser to move acer laptop notbook
have you tried hooking up a usb mouse? maybe your touchpad is disabled
Apr 11, 2010 | Acer Aspire 5315 Notebook
Touch pad and mouse butons don't work at all.
On laptops, sometimes your TouchPad is disabled for no apparent reason. To reactivate it, first try restarting your PC. If there’s no good change just try:
We need the software driver and your mouse are installed
This trick works in Windows XP and Vista
Go to Control Panel> Mouse> Settings tab of the device
Click <Enable> (or <Disable> to disable)
Please go through this image, will help you..
Notes:
On some models, there is a keyboard shortcut to activate or deactivate the touchpad. For example, a ACER, just do Fn + F7.
You can click Reset device if neither of those solutions will work. ..
Please revert for further clarification....
Jan 16, 2010 | Acer Aspire One PC Notebook
Hi.my touchpad don't work at all!!I can't do anthting with my touchpad.
The pad may be defective buy a cheep wireless usb mouse for it and use it to work without the pad. the pads do wear out and the replacement would be over a 100 Bucks.
Jan 15, 2010 | Acer Aspire 5100 Notebook
My touchpad stop work.pls help me!I have an acer
i found the issue you might have a bug where after it installs the FN Key actually locks out your touchpad. I just figured this out after installing all known drivers to man on my laptop. Lol, go figure a vista recovery bug created this error. Hope this helps you out (Hold in FN Key + The Mouse disable/enable key to possibly fix the touchpad)
Nov 22, 2009 | Acer Aspire 5535-5050 Notebook
Acer Aspire PC Notebook 5315 touchpad not working.
Hey in the control panel, go to the mouse, then look for the properties that have a PS/2 compatible mouse, you can change its settings there by sellecting other compatible mouse instead of PS/2, and also there is a settings or a check box that says the onboard mouse of your laptop will be disable if a usb mouse will be pluged.hope it soved your problem, :)
Oct 04, 2009 | Acer Aspire 5315 Notebook
Acer aspire 3000
The bootable XP cd you have will work - You need to first reinstall the Operating System(XP), then download and install drivers for the devices(Such as touchpad, wireless, etc.)
The device drivers are all available from Acer's support site; If the Network Card driver isn't installed after the windows XP installation, you will need to use a different computer to download the drivers, and transfer them to your laptop using some sort of removable media - USB Flash drive, portable hard drive, memory card, etc.
Feb 13, 2009 | Acer Aspire 3000 Notebook
How to disable mousepad?
normally the Fn and F7 key, it's the key with a finger on a square icon, or right click on the touchpad icon in taskbar>pointing device properties and select device settings and then dissable.
Sep 14, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3004 - Random reboots; random mouse program select w/o mouse click
the rebooting could well be a driver error, and you pc is set to reboot instead of stopping and showing the code numbers on a blue screen togive any clues, but it sounds as if it could be the touchpad driver. Go to my computer icon, right click>properties>hardware tab>device manager and look down the list for mice and other pointing devices and click the '+' sign and it will probably read synaptics touchpad, right click on it and select uninstal. Restart your notebook and the touchpad will be installed automatically and should, if the driver is not corrupt perform as normal.
Aug 11, 2007 | Acer Aspire 3004LCi Notebook
Acer Aspire 4315-2490 Notebook Logo
333 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
