Question about Refrigerators
Freezer not freezing, fridge is about 50 degrres in my lg side by
I have a 26 cubic feet LG LRSC26910TT refrigerator that is not cooling or freezing properly. It is 4 years old. I looked at rear, noticed condensation pan has overflow and not only ruined my hardwood floors, but also has rusted out the condensing coils. The motor still runs quiet, but have noticed it is running constantly. Any ideas?
    President:
  • 1,902 Answers
Check the relay on the compressor. But in order to due this right you are really going to need to have a company replace yor condensing coils and your drain pan. Check also the thermostats. Located under the dials to adjust your temperature settings. You can get some of the parts at repairclinic.com
Posted on Feb 22, 2009
Refrigerator is cooling but the freezer is not freezing
took back panel look like snow . if yes you defrost system not working . check heater cut off thermo , heater , timer
Jul 25, 2014 | Frigidaire Refrigerators
Why is Whirpool WRT111SFA 10.7 cubic feet not auto defrosting?
Hi Karen,
my name is Roger and i'd be glad to help you, most likely one of the components of the defrost system has failed. Or the drain got clogged and water is backing up and freezing over the air flow grids, inside the freezer.
Empty it and check the bottom of the freezer and back wall for ice build ups.
hope this helps
May 31, 2014 | Whirlpool WRT111SFAF 11 cu. ft. Top...
My Avanti refrigerator (about 12 cubic feet) is freezing everything in the refrigerator section.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Avanti 248Y Compact Refrigerator
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
The fridge section is getting too cold at the bottom
THE CONTROL THAT DIVERTS MORE AIR TO FREEZER AND LESS TO RE-FRIG SIDE COULD NEED TO BE ADJUSTED TO KEEP MORE AIR IN THE FREEZER SIDE , MAKE SURE ALSO THAT THE SMALL FAN IN THE FREEZER IS RUNNING , ALSO TURN THE THERMOSTAT CONTROL TO LESS COLD , IF YOU HAVE A THERMOMETER TO PLACE IN FRIG SIDE TRY TO KEEP @ APP 40 DEGREES IN FRIDGE SIDE SEE IF ANY OF THESE HELP
Feb 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ie tube freeze
You may need to balance the distribution of cold air between the freezer and refrigerator section.
The temperature setting influences both and there is normally a control that lets you divide the cooling between the two compartments.
If you don't have one, get an inexpensive (<$5 US) refrigerator thermometer, normally a simple dial-type, and monitor your refrigerator temperature (maybe somewhere in the middle) overnight when not often opened, set the main control to get the temperature between 40-45 degrees F.
Then check the freezer temp.; it should be <10 degrees F (0 is better), then swap back to the fridge to correct the main setting.
Go back and forth until you have both compartments close to the mentioned ranges.
Jun 24, 2008 | LG LRSC26940ST 36" Side-by-Side...
Refrigerators Logo
308 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
