Question about Panasonic PT-53WX42 53" Rear Projection Television
Tv has lost it's brightness, dark scenes are almost unviewable
Whether viewing the tv from a satellite dish or a dvd, the picture is dark and I have adjusted it to increase brightness but the people in the scenes are dark.
  • Panasonic Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiTv has lost it's brightness, dark scenes are almos - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Tv has lost it's brightness, dark scenes are almos - 578ba6c.jpgef="" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Posted on Mar 26, 2009
Color is grate on my Sharp 26" TV. However night scenes have become almost too dark to see. I have tried to adjust the settings but no improvement. Is this a fixable problem? Using Comcast Cable a
Check 'brightness' and 'contrast' settings in (usually) 'picture' menu. Use a recording (DVD etc.) of a dark scene to adjust the picture. My TV (not Sharp) has several pre-programmed picture settings. If yours has that, maybe one of them will be good. Otherwise, use manual settings.
Oct 18, 2014 | Sharp Televison & Video
The picture is very dark
Unfortunately, there is no easy fix for this. If it were a rear projection TV, I'd suggest a new bulb. Even on a Plasma there are things that can be done. But on a CRT, the repair for a dark screen usually costs more than replacing it.
Sep 20, 2007 | JVC AV-32F702 32" TV
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Brand new 47" "Edge Lit" LED, model MV4(Cant
I believe there may be another setting, it has to do with auto contrast which can make the TV seems to have high contrast ratio but sometime it does not work right, espically on the scene with dark sky with stars, someitme it will will reduce the brightness to make black real black and you can loger see the stars in the scene. I forget the name of this setting, it may be in the user manual. Do you see that in TV HD mode in other movies with a lot of dark scenes?
Dec 01, 2010 | Televison & Video
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
May 04, 2009 | Televison & Video
Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
Oct 19, 2008 | JVC AV-27530 27" TV
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Picture is very dark
Is there a simple fix for this, yes The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak but as you have bought in 2004 so possibility is rear. good luck
Panasonic PT-53WX42 53" Rear Projection Television Logo
170 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
