FixYa.com
Tags:
Thermalright SI-97
A7V8X and Volcano 9 (Beeping Mobo)
By Ross - usenet poster
Ok, I've tried every damm config setting possible with two volcano 9's in my
ABIT KV7 and ASUS A7V8Xand I get the same result
everytimeboth systems run fine with their regular CPU fans before
and after tests.
the result is when the system powers on, the fan kicks on for 2-3 seconds
(nothing else powers on) then the fan turns off, and then the mobo starts
beeping continuously. ARGGGG. Any thoughts on this?
And yes, I attached the 3pinTo4pin power adaptor, and also attached the
yellow cable to the CPU fan connector. It seems as if the mobo thinks
their is no fan running when their is.
Marc Miles
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Beresford
Beresford - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I tried all three, variable, full, and sensor. All had the same problem.
Yes, its probably me just needing to disable Q-Fan, I will try that
nextyes, the fan is Thermaltake.
Its not the PSU.
Marc Miles
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
On my A7N8X-Deluxe I have Q-Fan disabled in Hardware monitor..on the other
one it is something like CPU Fan detect...not sure but it might be
Q-Fan...did you try Thermaltake?..also try disconnecting all your
peripherals and then boot...just have your vid,ram and cooler running..no
hd's or cd rom's..it might be drawing to much juice if your PSU is weak.That
happened with my older PSU , I had to replace it.
Solution #3
Not Rated (0)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
I run that feature disabled on my system with a Volcano11..and the other one
has it disabled with a CU6+...is the 9 a variable speed?...if it is turn it
up.But if it isn't and you do not want to disable the feature..then you are
going to have to run stock or find another solution..swapout the fan for a
higher speed one
Solution #4
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
That's what I was thinking, so, If I disable that setting in the bios, and
then the fan does actually fail, the mobo will fail to shut itself down and
thus overheat costing me $$$???
Marc Miles
Solution #5
Not Rated (0)
Beresford
Rating: 0%, 0 votes
what feature exactly should be disabled, I'm very cautious as to disable
something that is there to prevent harm to my mobo/proc. I have parts that
cannot be returned and cant afford a new cpu/mobo.
Marc Miles
Solution #6
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
there should be a setting in the BIOS to disable that shutdown
feature..disable it while you have a stock cooler on and then change it.
Can you Help with these System Cooling problems?
System Cooling
damaged printed circuit board...
I don't think I'm in the right... Answer This...
System Cooling
Air Condition
Ac only works for a minute or... Answer This...
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
