Question about Lexmark X5150 All-In-One InkJet Printer
Printer Driver error LXBADR5C.DLL
Trying to reconnect printer, Lexmark 5150. errors stated above. Cannot connect. Can you give me steps to do so.
  • 447 Answers
Reinstall the printer from the original driver disc or download the drivers from this page.
Posted on Feb 22, 2009
Scanner stating cannot retrive application list for my lexmark x5470
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/dbCiI6. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
Unable to carry out print command
Issue : Desk jet 5150 Not printing
Environment :
OS - Not provided
Printer : Deskjet 5150
Solution :
There could be 2 reasons for your problem
check the following links
Solution 1 fig are available
Step 1: Press the Resume button
Press the Resume button. Wait for approximately one minute and then print a self-test by pressing and holding the Power button and pressing the Resume button four times. Release the Power button. The self-test page should print. If the carriage is still stuck, go to the next step.
Step 2: Power cycle the printer
Turn the power off and back on, following these instructions:
1. Turn off the printer by pressing and releasing the Power button. If it will not turn off, proceed to Step 3. If it does turn off, proceed to the next step.
2. Turn on the printer.
3. If the Power light is on steady, print a self test with the instructions above in Step 1.
Step 3: Clear the paper path
Reset the printer and clear the paper path of any paper that may be jammed in it, using the following instructions:
1. Leave the printer turned on and disconnect the power cable and the USB or parallel cable from the back of the printer. Do not reconnect them until instructed later.
2. Remove the paper from the in-tray.
3. Remove the rear access door or duplexer (if installed) from the back of the printer.
Figure 4: Removing the rear access door
4. Open the top cover of the printer.
5. Check for and remove any paper still in the printer. A paper jam could cause the error message and the carriage stall.
6. Replace the rear access door, close the top cover, and replace the paper in the in-tray.
7. Reconnect only the power cable. If the printer does not automatically turn on, turn it on with the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, do an internal test as described in Step 1 above.
If the carriage is still in a stalled position, contact HP Technical support to have the printer serviced.
IntroductionWhen printing with a HP Deskjet printer on Windows XP, the user may get the following error messages:
  • Error with USB
  • Out of paper message
  • Error lost communication with printer
  • Any other error messages related to communication.
The following performance failures could also be observed:
  • Partial page is printed, then ejects incomplete.
  • Blank page is ejected with nothing printed on it.
InstructionsThe error may be either a hardware or software issue. Firstly, make sure that all connections between the printer and PC are secure. Secondly, check if the printer can perform an internal test. Once the internal test has been printed properly, follow the instructions below to install a generic printer driver to know if HP printer driver is working fine:
  1. Click Start , Control Panel and Printers and Other Hardware .
  2. Click View installed printers or faxes .
  3. Highlight the printer to be removed.
  4. Click File and Delete .
  5. Click Yes when the deletion confirmation screen appears.
  6. Click File , Server and Properties .
  7. Click on the Drivers tab, highlight the printer to be removed and click Remove .
  8. Click Yes when asked to confirm deletion.
  9. In the printer folder , click on the Add a Printer task.
  10. Click Next and then, the Add New Hardware Wizard screen appears.
  11. Click Next on the Local or Network Printer screen.
  12. Click Next on the New Printer Detection screen.
  13. Click on the down pointing arrow next to Use the following port box and select USB001 or USB002 (virtual printer port for USB) and click Next .
  14. Under Manufacturer option, please select HP .
  15. Select the appropriate printer and click Next .
  16. Select Yes when asked Do you what to use this printer as the default printer? and click Next .
  17. Select Do not share this printer and click Next .
  18. Select Yes or No when asked Do you want to print a test page? and click Next .
  19. Then, click Finish .
  20. Try printing.
Jan 03, 2010 | HP DeskJet 5150 InkJet Printer
New computer won't print on old Lexmark 5150 printer
You can download the latest driver from lexmark.com .
May 05, 2009 | Lexmark X5150 All-In-One InkJet Printer
ERROR 1208 LEXMARK 4270 LOST MY MAN. WHAT DOES THIS MEAN. WILL NOT PRINT HELP!!!!!!
Important News Attention Windows Vista Users: Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Dec 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error
what operating system are you using?
Aug 13, 2008 | Lexmark X2250 All-In-One InkJet Printer
Cannot complete operation error 0x00000006 what mean?
Lxcrdr5c.dll error code
Hi I have hd the above error reported for months on my printer and no ammount of web searching delivers the solution or can I find the missing driver/component on my harddrive
Jun 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error Scanning from All-In-One to Vista
This appears to be a Vista driver software issue- check out Lexmark for any updates
You can also try the followng.
go to--- Start/Programs/Accessories/system Tools/Compatibility Wizard and try resetting the machine to run as XP
Jan 25, 2008 | Lexmark X9350 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
111 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
