Question about U-Line BI-95
Bad taste and smell in water at kitchen sink faucet
We just installed a new faucet and supply lines. The supply lines are white hose type (not PVC). Since the change, the water has a bad taste and smell. It is not like rotten eggs, more like metallic and the water from the bathroom facets are not affected.
What can we do to resolve this problem?
    President:
  • 1,902 Answers
Check your water filter inside the unit up in either the left or right side of the top. If you do not have a filter then add a filter to the unit on the supply line to help with this problem
Posted on Feb 22, 2009
  • 54 Answers
Install a charcoal water filter on the end of your faucet. You can pick one up for under $40 at the local hardware store, installation is easy and only takes about 10 minutes.
  • dvsjjs Oct 22, 2010
    But why does the new faucet cause this? Is this common? I would rather not spend money on a filter - would rather take the faucet out, return it and get one that does not cause the water to taste bad. don@rockanchorage.com
Tuscany kitchen faucet
The hose is always filled with water when not in use. The longer that water remains stagnant in that line, the more it will absorb that smell. Try running the water for 10-15 seconds before filling your glass. If that doesn't solve the problem, purchase a new hose.
Oct 20, 2013 | Plumbing
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
Sour smelling/ tasting water from bathroom faucet when not used for several hours. Smells like traces in water bottles, which I can bleach or wash in dishwasher. How do I clean possible bacteria from a...
Assuming the problem is right there at the faucet, and not further upstream (which you could verify by taking a little water from the tub faucet), perhaps you could try this--- turn off the water supply then remove the flexible water supply lines from the faucet underneath the sink. These are usually not too hard to remove from the faucet with a basin wrench (less than $10). If it's easy, remove the other end of the flexible water supply lines too. Maybe you should replace these. Otherwise, get the water out of those flexible line, then put some bleach into them. Reconnect to the faucet. Leave the faucet turned off, and turn the water supply back on. Then very slightly turn on the faucet to allow the air out, then turn it off. Leave the bleach to soak for a while (maybe 30 minutes) then flush plenty of water through it. If the smell comes back, there is probably something organic stuck in the faucet and you will have to disassemble or replace it. Good luck.
Dec 20, 2010 | Home
Strong sulfur-type smell/bitter taste to water in only 1 faucet
The only thing I can think of that would cause one faucet to do that and not the other is the water line in that small stretch between them is a different metal. ie; galvinized to copper. If not properly adapted with a diaelectri or at least 4" of brass, it will cause electrolosis. Never seen electrolosis in action, so I'm not sure if it causes that smell and taste.
If you don't see a water line issue, then replace your faucet to see if that solves the problem.
If you have any further issues after that , I would suggest calling a plumber. good luck
Jul 16, 2010 | Home
The water in our kitchen faucet sometimes smells like a rubber hose. If I run the water for a few seconds, the smell goes away. The smell is also under the kitchen sink all of the time. Probably because it...
Try to follow the water supply pipe all the way to the meter. It might have a rubber hose connected to it. Could have been some ones leak repair.
Nov 09, 2009 | U-Line BI-95
Refrigerator Water Hose
copper is best with compression fittings, just install an in line filter
Sep 29, 2009 | Refrigerators
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Apr 08, 2009 | Grohe 32.074.KD0 K4 Prep Sink Single-Spray...
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Bad tasting water and ice from fridge and kitchen tap...
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
Jan 05, 2009 | U-Line BI-95
We are getting a metallic taste and smell
The metalic taste is coming from the the new faucet
I would call American Standard and ask them if they have any complaints for this particular model
I would run hot water through the faucet for 5 minute intervals
If it persists I would take it back and demand a refund or cal AS and demand a refund or replacement model
I am sure the local news would like to report something like this
Jan 05, 2009 | American Standard Kitchen Faucet 6310 020...
U-Line BI-95 Logo
2,441 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
