Question about Thermador PRDS364GLUS Dual Fuel (Electric and Gas) Kitchen Range
The grill igniter stays on when the knob is in the off position
Thermador prds364glus everthing works fine on this range. the problem is that the grill igniter stays on when the knob is in the off position. i tried jiggling the knob but no good. any help would be greatly appreciated. thanks
5 Suggested Answers
SOURCE: Flashing Lights on Thermador Oven/Range
I HAVE THE SAME PROBLEM. MY OVEN BINKS ONCE FROM BAKE AND TWICE FROM THE OTHER LIGHT. OVEN DOES NOT WORK, ADND WE REPLACE THE CONTROL BOARD ALREADY. WHAT DOES THAT MEAN?
Posted on Jan 31, 2009
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Posted on Mar 06, 2009
SOURCE: Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Posted on Jun 03, 2009
  • 193 Answers
SOURCE: Wolf Commercial Gas Range: turning knob on and off very difficult
easy pull the tap apart and clean it with metho and repack it with gas tap grease and take note how you pull it apart also watch out for the spring in side it
Posted on Apr 26, 2010
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Thermidor GG30 cooktop front large burner will not light, does not spark. Three other burners work fine. Need instructions how to disassemble and repair. I am handy but no experience with this item. ...
Here is the part to order.
Close the valve in the gas line connected to the Thermador oven. Unplug the cooktop's electrical cord from the wall outlet.
Remove the screws under the front edge of the Thermador cooktop below the cabinet to release the cooktop from the countertop.
Put on work gloves then raise the cooktop at an angle. Recruit a friend to hold up the appliance while you work on the igniter underneath. The igniter is a pronged strip of black metal in a housing wired with two plugs connected to powericon1.png sockets underneath the Thermador cooktop.
Disconnect the two wired plugs on the end of the igniter from the sockets.
Take out the two screws in the metal plate that hold the igniter in position under the Thermador cooktop. Pull the igniter out of the mounting bracket in the cooktop.
Hold the new igniter by the housing and insert the part into the mounting bracket. Secure it with the two screws.
Connecticon1.png the two wired plugs to the sockets. One plug is larger than the other, which makes it simple to connect them correctly.
Lower the Thermador cooktop into position on the countertop and reattach it with the screws through the underside of the front edge.
Plug inicon1.png the cooktop's power cord and open the valve in the gas line.
Feb 09, 2013 | Kitchen Ranges
Thermador Cook Top Model SGS365FS. All ignitors continuously "click" when turning only one knob. Once the gas is lit and you turn the knob off of ignite all ignitors still continuously click. Each
THat is the way the igniter circuit works...all burners activate at the same time...that is a safety precaution in case more than one burner is on. As far as the igniters continuing is concerned, there is a problem with one or more than one of the push in to ignite knobs being stuck in the in position. Use some CRC or WD40 spray on the shafts behing the knobs by removing each knob and spraying where it slides.
Jan 02, 2013 | Kitchen Ranges
GRILL IGNITES BUT WILL NOT STAY LIT
If its not staying on and going out as soon as you let go...then this sounds more of a thermocouple fault to me. All cookers have these on every burner now. Remember always use a gas safe engineer!
Sep 18, 2012 | Cannon Chesterfield C60G Kitchen Range
2 of my burners keep clicking, even when completely off
Did you recently clean the range? If you get liquid into the igniter switches(located behind the gas control knob) or into the contacts where the igniters are located then it can cause a short and make the igniters to operate even when the knob is off. So if that is the case then the only fix is to unplug the range for 24 hours and let the liquid dry out. If the liquid is not the problem then it could be the igniter switches in the gas control knob are broken and stuck in the closed(on) position.
Jan 14, 2010 | Thermador PD366BS Dual Fuel (Electric and...
Igniter problem on Dacor grill
After flame ignites you have to turn knob back to the "ON" position only.
Nov 07, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Jul 02, 2008 | Thermador PG486GEBS Stainless Steel...
I have a 6 burner Thermador Gas Cooktop SGS456ZB. I have a problem with one of the ignitors. It keeps firing the entire time the burner is on. The other 5 ignitors and burners including the 2 extra-low...
Dear Kathynearing,
Hi. I have experience cooking in a burner like that it keeps on burning coz the ignition coil was press by your switch knob coz the spring was stack up try to release it so that it will not be ignited all the time when your cooking. This should be ignited at once. If it gives light already it should be released. Please reply if you have solved the problem so that I can give you more advices.
Mar 30, 2008 | Thermador Kitchen Ranges
Thermador PRDS364GLUS Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
