Cannot eject disc from wii
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,
that gives step by step information on Dis-Assembling with screenshots,
even a novice can fix the disc eject problem with the help of this DIY
Guide. It also gives information on fixing many Wii Related Problems,
so its a kind of Wii Problems Reference Fix Guide
SOURCE: wii game disc will not eject
you have three choices, 1. send it to get disc out, 2. take apart yourself or 3. keep pressing eject button till comes out, ( try laying it flat, on side and upside down).
http://www.wii-ftw.com/?page=disassembling_wii
SOURCE: Ejecting Wii disc while power is off
SOURCE: disc stuck inside Wii Consule
Unplug everything from the system and the power cable from the wall or power strip, let it sit for about 5 minutes. Plug everything into the system first then the wall. Power should come on
If the disc does not eject, contact nintendo, the disc drive will need repair
SOURCE: the Wii keeps ejecting the disc and we can't play on it
With the Wii Console vertical, the discs should be loaded with the shiny side to the left. If you are loading like this and all discs are being ejected, then you very probably have a problem with the Wii Console.
To ck into repair go here:
http://www.fixya.com/ThreadView.aspx?thid=2204194&prdid=618512
