Question about KitchenAid KGRS807SSS Gas Kitchen Range
KITCHENAID KGRS807 ERROR MSG F6E0
We went to use the oven and an error msg of F6E0 is now displaying on the oven and will not come on. Stove top works and starts fine. What is this code? Looked in the owners guide (1/1/2 old) and it doesnt have it in the book. THANK YOU FOR ANY HELP
  • Jvkf Apr 25, 2009
    I have KitchenAid range model YKESS908SS01 SER. XW4408608 and I have received error F6EO Communication problem.
    After turning oven on adn of serveral timess error disapiried.
    President:
  • 1,902 Answers
Problem with the time keeping unit. You will need to reset the unit. Unplug it for 30 minutes then plug it back in. If that does not work then check for bad ground wires that are not fully grounded on the unit. If you find a problem and need to order the part you can order it at repairclinic.com
Posted on Feb 22, 2009
Kitchenaid oven won't turn on
FOLLOW the OWNERS instructions to TROUBLE-SHOOT (EG remove the door, clean it & replace it properly, etc.). On my model... check the center top for a simple switch lever... than gets pushed straight in when the door is PROPERLY CLOSED...
(light should go OUT).
ELSE your door switch "thinks" your door is open =
BROKEN or DEFECTIVE DOOR SWITCH
ServiceBench
As much as I detest SEARS... KITCHENAID is close behind:
If you cannot find your door switch issue on a REPUTABLE PARTS SITE
SEARS does have some "COMPETENT EXPECTATIONS"
for their repair service... Act quickly... SEARs is deservedly going out of business.
But first look around... for GOOD VIDEOS
(NOT YOUTUBE)
appliancepartspros, ereplacemntparts, partsselect.com
My KGRS807SSS00 Model Overview from PartSelect com
Search Over 2 1 Million Appliance Parts
Jan 23, 2017 | KitchenAid Kitchen Ranges
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Error code F6E0 on Kitchenaid KGSS907000 wondering if it is the control board or touch screen, what other components could cause this?
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control board
May 02, 2014 | KitchenAid Architect Series KEBC107KSS...
Kenmore 790 oven won't maintain temperature
anyone know where to buy the battery for hand phone model mini i9500 ? manufacturer is
z.doxio
Nov 12, 2013 | Kenmore Kitchen Ranges
Oven does not work is reads F6E0 error code lost communition what's wrong?
I assume it's a KitchenAid that you have. Here you can find a previous thread about this code:
http://www.fixya.com/support/t1176150-f6e0
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Ovens
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
I have a two ear old Kitchenaid gas range (KGRS807). It all at once stopped lighting the oven. The top burners still work fine. When you do anything in the oven (Bake , Broil, Convection) the electric...
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Apr 16, 2010 | KitchenAid Architect Series KEMC308KSS...
Same thing with my one and 1/2 year old KGSS907 series stove
Yes it is fixed. Did a temporary jumper of the over temp fuse to use the oven one night. Installed a replacement 130 degree fuse with a mica transistor insuator under it instead of being mounted directly on the back side of the oven. This raised the range to about 150 degrees.
Thanks for the help
Aug 25, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KGRS807SSS Gas Kitchen Range Logo
3,262 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
