Question about Haier HWD1000
HALF LOAD I CANT GET HALF LOAD ON MY HAIER DIGITAL MACHINE
  • 3 Answers
The machine will not spin for you if you try to do a small load , you will only get UNB , this is why you have no Half load, hope this helps
Posted on Mar 04, 2009
HAIER ENCORE WASHING MACHINE MODEL GWT750AW WONT DRAIN
Most likely pump but could be logic board not calling for machine to drain.
Nov 20, 2014 | Haier GWT750AW 4 Cu. Ft. Encore Top Load...
How do i troubleshoot for a ball sensor,switch on a LG laundry washer?
machine needs to be level.so it cant rock side to side or front to back adj feet .when u load machine put half in and rotate drum half turn and put the rest of load in.that should balance load.dont overload.try running empty if it still showing ua
Aug 09, 2014 | LG WM Washing Machines
My Haier washer can not rinse and spin
My Haier front loader can not spin out correctly it's to loud and shakes back and forwarder spinning out on the wrong load because the size load button is struck in side the machine and won't pull out.
Sep 29, 2013 | Haier Heating & Cooling
My Haier HLP21E top load washer is only one month old, and there is some leaking from under the machine.
Check the hose clamps on the bottom. Sometimes the clamps are not all the way on or tight enough. I saw one that did the same thing.
EDIT: one of the mounting screws on the bottom of the tub will create a "tear" (or another word that rhymes with track) in the tub (Fixya says "The word $@#%^ is considered as profanity on Fixya. Please review your answer and try again").
I used a plastic soldering iron from Harbor Freight and cut a piece of the plastic webbing off the tub to "solder" the hole shut on the tub.
Aug 22, 2012 | Haier HLP21E Top Load Washer
Haier washing machine error 1 message does 1 mean fatal or fixable
You need to close the machine door, thats what error 1 means :)
Jun 09, 2010 | Haier XQG50-QF80 Front Load Washer
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Loose drum!!!!
inner drum is tightened usually with a bolt thro the main pulley (sometimes a nut) but this is unlikely to be the problem. suspect you bearings have worn.
Apr 24, 2007 | Haier XQG65-8SU Front Load Washer
Haier HWD1000 Logo
131 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
