Question about Matsonic MS9327E (MS9327E+(USB)) Motherboard
Upgrade proc from 1.7 to 2.8 ,
Hi i have a ms9327e + usb motherboard im having problums upgrading the proc , i put the processer in i hear a beep like normal but nothing comes on screen i not sure if processer is damaged but was assured it worked as its second hand of ebay came in recomemned box , was wandering if i need to change anything on the motherboard >>>> please help , thanks
    Scholar:
  • 85 Answers
Try to find out from manufacture which processors are supported in different bios versions. You might have to upgrade the bios with your old processor as long as the bios you are upgrading to supports the new processor. This is true even if you have to downgrade bios meaning going to an earlier bios. It might not go into bios after the first reboot with old processor because it might not be supported but your new one is. this is when you do the CPU swap.
Posted on Feb 22, 2009
  • Chuck Feb 22, 2009
How can recover my deleted/flashed bios
Remove the side panel of the computer case, using the screwdriver to unfasten the screws normally located in the back.
Remove the jumper from its normal position on the motherboard and place it in the recovery position.
Usually, the jumper will need to be moved over one space to cover a previously exposed prong.
If the motherboard does not have a jumper, removing the battery for 30 seconds and then replacing it may have the same effect.
Insert the BIOS flash disk and power on the computer.
If you used a flash tool or utility and did not create a BIOS flash disk before flashing the BIOS, then you will need to do so using a functioning computer.
Since there will be no video, listen for the internal PC speaker to beep.
This means it is performing the BIOS upgrade.
Power down the computer once the BIOS upgrade has been completed.
This process may take some time to complete, so be sure to not turn the computer off before the BIOS upgrade is finished.
Without video, the only way to be sure is to listen to the PC speaker.
When the upgrade is done, the PC speaker will beep again, and the floppy disk drive will turn off.
Replace the jumper back in its normal position and put the side panel of the computer back on.
Power the computer on.
If the computer turns on as normal, the recovery was a success.
hope this helps
Sep 25, 2012 | Compaq Presario 700 470024-192 Notebook
Matsonic ms9327E+ usb Manual
Matsonic has the manuals for their MS9327E motherboards here: http://www.matsonic.com/Computer-Desktop-Support/Models/ms9327e%2B_usb.php . The direct link to the manual is: http://www.matsonic.com/freeManuals/MS9327E.zip .
Alternatively, try this file: http://www.desktop-computers.ws/secure/MS9327E-USB_087d3e4719fb207d963c30d120864c13.zip . If that isn't the correct manual, start at http://www.desktop-computers.ws/desktop-computer-search.php and enter the motherboard model in the search box.
I hope this helps.
I hope this helps.
Jul 23, 2011 | Matsonic MS9327E (MS9327E+(USB))...
I need MS9327E-USB - VGA driver for windows 7
http://www.givemefile.net/drivers/mainboards/msi/file/13241.html
This motherboard may not be windows 7 compatible. Try that driver though. It could possibly work. Let me know if it did.
May 12, 2011 | Matsonic MS9327E (MS9327E+(USB))...
I shipped my gateway to the philippines and had been using it until I had to leave. It has sat idle for 2 1/2 years. When i returned I brought new parts to upgrade, harddrive, memory, and a new windows xp...
Hello sir hi, try cleaning the memory modules of your PC. also review your power supply connection. and check the following sequence of events. 1. power on the PC. 2. fan should be blowing. 3. keyboard light, scroll, numlock and capslock lit and then goes off. (if this does not lit, you have a mother board problem) 4. you should hear a beep. (1 beep is normal, 1 long and 2or3 short beeps, means display problem) 5. the numlock is lit. (no light means problem on the motherboard) 6. the display monitor will now display the CMOS. 7. your drive should turn/spin or HD led lights.
Im not so sure if the motherboard develops errors due to being not used for a long time, and may now have slimes and battery leaks that may be present on the board, a visual inspection is needed here, remove your motherboard out of the case and inspect all area for chemical creeps.
Nov 20, 2010 | Gateway Tabor 3 (4000532) Motherboard
I want to max out the 2g memory upgrade, what do you recommend?
If this motherboard is still in your tower then visit Crucial.com, there you can use their System Scanner Tool and it will tell you whats is compatible to install.
Aug 28, 2010 | Matsonic MS9327E (MS9327E+(USB))...
What are the processor compatible with this mother board pvmm2? my current proc is celeron 1.8ghz. im planning to replace it with p4 proc? i tried p4 2.26 ghz but it wont work?? pls give me adviced for...
http://www.ecs.com.tw/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=272&MenuID=69&LanID=0
Note that a faster front side bus(FSB) or system bus as listed on the above page will make a slower cpu faster the a cpu with higher Ghz and slower FSB.
Also RAM is your best upgrade, fast and easy.
Jan 10, 2010 | EliteGroup P4VMM2 Motherboard
1 beep on a Sapphire PC- AM2RD580
hi im josh in cebu phils. friend do not overclocked your pc. go to the bios again and select the restore default. snce that is on beep try check first the video card and the memory befre you restore the defaults. good luck
Jan 31, 2009 | Sapphire Technology (RS300-MA39)...
Looking to upgrade video. is there a limit to uprade old mboard
Only cards that work with this board are AGP 4x graphics cards or possiblly AGP 8x cards that are backwards compatible. If you buy an 8x card do your research to make sure it's backwards compatible before purchase. Newer graphics cards are pci-express x16 or pci-e 2. These will not work with your board. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Matsonic MS9327E (MS9327E+(USB))...
Processor Compatibility
Hi your mobo can support processors of 400 FSB . The best you could do is use a 2.4 or 2.66 ghz processor . Processors of 533 FSB or beyond are not supported , all these are uni core proc., the newer procs., are all dual or quad cores so beware do not buy a wrong processor
May 12, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
Upgrade
to upgrade your going to have to take the laptop apart and remove the heatsink on top of the cpu, then disconnect the cpu, and then install another cpu in place of it, apply therman greeze and put the cpu heatsink back on. and reassemble your laptop.
Mar 31, 2008 | Computers & Internet
Matsonic MS9327E (MS9327E+(USB)) Motherboard Logo
138 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
