Question about ASUS P4P800-E DELUXE ULTRA ATA133 W/SATA,RAID,LAN(Gb),1394,USB 2.0&AUDIO (Retail Box) (MBASP800) Motherboard
Pc halted I got a fatal error when i open my pc. It sound like this "Chassis intruded, Fatal error...system halted"
    President:
  • 2,692 Answers
Thier is a switch attached to the side of you case ans in the even that the side is open the switch stops the computer from operating. This is xcalled a Chassis Intrusion switch. You may just disconnect the switch. it is is not working correctly.
Posted on Feb 22, 2009
    Scholar:
  • 85 Answers
Very simple shut down computer put side panel back on and restart go into bios and under the settings somewhere you will see enable chassis intrusion. Just disable that. If you put cover back on then proceeded by turning power on and you still get this error than it is time to clear CMOS and then you must go into the bios and hit setup default and then go into any timings and voltage settings for CPU Memory and such. and also disable the chassis intrusion. You can enable it at anytime. just as long it is not powered up when removing side panel. I hope this is helpful.
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Jul 24, 2010 | ASUS P5V800-MX Motherboard
Chassis intruded ! fatal error.....system halted
Some cases have a switch that activates if the case has not been closed fully.
This sounds like the type of error report this problem causes.
Make sure that your pc case is fully closed and has not been damaged
Jul 11, 2010 | ASUS P5LD2-VM Motherboard
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Dec 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis Intruded !Fatal Error ! System Halted
the motherboard detected movement or the computer casing was opened whilst the pc was on.
check to see if the case is open of if the conacts are ok.if the problem persists you may have to turn off the feature in bios
May 19, 2009 | ASUS A8R32-MVP Deluxe Motherboard
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
Apr 07, 2009 | ASUS A8R32-MVP Deluxe (A8R32MVPDLX)...
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis Intruded, Fatal Error.....System Halted
I'm not familiar with that particulat model, but I'd guess the motherboard has a chassis switch connector, and senses the chassis be open. Could be because: - chassis open (close it), - switch defect (as a workaround, you could short-circuit it, or just unplug it - whichever solution works for you). As another workaround, you can probably disable this switch in BIOS.
ASUS P4P800-E DELUXE ULTRA ATA133 W/SATA,RAID,LAN(Gb),1394,USB 2.0&AUDIO (Retail Box) (MBASP800) Motherboard Logo
382 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
