Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Missing part(s) on clutch but not sure the actual part number
I'm missing a part (washer and possibly other small parts) on what I think is the clutch. It is located where the chain rotates behind the guide bar. I can not locate a diagram. The parts listing does not show pictures or details.
I'm looking for a diagram if possible.
  • 2,176 Answers
OK you can go to Poulanpro.com and need your exact model number or I just went by the 42CC and took a look at a breakdown that you can download It is a very good schematic and I think it will help you. Let me know if I can help any further.
Posted on Feb 22, 2009
Why doesn't water wring out of clothes
There is a "clutch" that enables the tub to spin but the clutch linings are worn out.
The repair is not too difficult.....I would say that the repair level is about "6" on a "1 to 10" scale.
There is also a possibility that there is a mount that has split into pieces.
Those are the two most likely suspects....
For some reason (I think it was to save money, some Kenmores are actually MISSING one mounting bolt for the gear case / transmission assembly....I looked at mine and I figured that the reason that the mount was broken was because the mechanical assembly was missing the bolt which caused more vibration every time the machine went into a spin.
Jul 15, 2014 | Kenmore Washing Machines
Kenmore dishwasher not draining
There are several reasons why the washer won't drain...
Here are the most probable answers:
1. There is a "clutch" that enables the tub to spin but the clutch linings are worn out.
2. There is also a possibility that there is a mount that has split into pieces.
3. The water pump impeller may not be turning....
4. The drain hose is kinked or not positioned properly (above the level of the water in the machine)....
Jul 14, 2014 | Washing Machines
Chevy malibu 2001 code po300
P0300 is multiple cylinder misfire, meaning a engine miss is detected on more then 1 cylinder, I would have the codes scanned at auto part store to know for sure which cylinders are actually missing, if there are 2 cylinders that are missing and they are side by side, such as cyl. 1,3. Or 3,5. If so its possible u have a blown head gasket blowing in between the 2 cylinders.. 1st double check that your wires are installed correctly, the coil packs have numbers on them to assure proper location.. Note the rear head has cylinder 1 3 and 5. Some people get that confused.. Providing you have a 3.3, 3.8 or 3.1 liter engine.
Jun 10, 2012 | Chevrolet Malibu Cars & Trucks
When I press the start button the light flashes but the washer does not start
Sounds like a faulty latch. The dishwasher thinks the door is open. Should be part number 154529403, but double check it with parts store, as the model number provided is missing a couple digits.
Apr 05, 2010 | Frigidaire 24 in. GLD2250RD Built-in...
I put a new clutch in my 89 yz 250 when i rebiult
There should be a small bracket that sits over the actuator arm and is screwed into the cases. This is what holds it in place and keeps it from popping up
Oct 22, 2009 | 2004 Yamaha YZ 250 F
Simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
Jun 22, 2009 | Washing Machines
Tub Slipping On Spin Cycle ( Direct Drive No Belt) Possibly Clutch ????
It is possible the rear counter balance spring has come off or the hole that the spring hooks onto has rusted. If the spring hook end has broken off you can often just bend a new hook part with a couple of pairs of pliers. If the hole in the washer frame has rusted, you will need to drill a new hole to hook the rear balance spring into. If the spring "took off" somewhere and is now missing, time for a new spring.
click this link directly for diagram
http://www.applianceaid.com/directspring.html
hope this helps.
May 03, 2009 | Kenmore Washing Machines
Hello, I just received a used Toshiba tecra 9000 laptop and it is missing the "mouse" and I need a part number so I may buy one.
Since the Tecra 9000's mouse is actually the Accupoint that's located within the keyboard, it cannot possible be missing the mouse (unless it's missing the keyboard).
Unless you're missing the Accupoint cap. Only place to order them is from Toshiba Support.
Feb 03, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Snap-on Parts replacement
I think you are descibing the headlamp wash system that is missing between the headlamps. The theary is that every 7 times the windscreen is washed the washer jets pop out from the bumper and blast the headlamps with water. They were fitted as an extra rather than standard so if the cost of replacement is to expensive it would be favourable to just replace the plastic cover to hide the hole. You may find that the water jets are in place and its only the small plastic cover that is missing. The grill under the licence plate mount is mainly cosmetic but care should be taken incase other adjoining parts are loose. Hope this helps.
Sep 15, 2008 | 2002 Jaguar X-Type
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
139 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
