Question about Quantaray 7-Inch Digital Picture Frame - View your photos right from your memory car...
Quantaray 5.6 Digital Photo Frame not working properly
My Quantaray 5.6 Digital Photo Frame seems to be "spazzing out" on me when I insert my flash drive full of pictures. I've been inserting the flash drive via the usb port then selecting the usb icon on the main page. It displays a page of thumbnails then suddenly they all disappear and start flashing rappidly as if its stuck or frozen. I managed to save 2 to favorites and disconnected the flash drive. I am able to get the 2 favorites to view properly but NONE of my settings I change seem to take effect. I set it to display each photo for 30 mins and selected a transition. When I finish up and then go to favorites a slide show begins but the photo changes every few seconds. I can't seem to understand what is wrong with it, I've followed the directions to a tee and I'm beginning to wonder if its just a piece of ****.
It is definitely a piece of S**T!
  • Quantaray Master
  • 5,412 Answers
Maybe if you were to calm down and approach the situation calmly, you could figure it out. Or, or course, you could try looking in the manual - that often helps.
Posted on Mar 13, 2017
4 Suggested Answers
  • 44 Answers
SOURCE: I have a quantaray 10.4"
I don't believe they came with memory cards. You need to insert your own memory chip into the frame. The connection points should be on the sides of the frame or in back. You should see slots & perhaps a USB port. Let me know what you find.
Posted on Dec 10, 2008
SOURCE: I have a Quantaray 7"
On the opening frame when you turn it on Scroll through the icons to "setup" . Press enter.. A screen will come up sayinf "set up menu-photo setting"..Scroll down the left column to the center multi color icon and press enter. Press the right arrow on the handheld. In the grey box that comes up you will see various controls.. The third on the list is "brightness" . Press enter and then right arrow .. Scroll to setting you desire. (Normal, bright or soft are offered).. Good luck..
I also posted a question that you may know the answer to. How do I load photos on to the unit from my computer. I see there is a USB port on the Sunpak and I have a USB port on my computer .. but no cord with 2 USB port ends?
DH-L
Posted on Jan 02, 2009
SOURCE: customer service to help me to use quantaray by sunpak
I have a quantaray 15" photo frame and I cannot get the screen bright enuf to see the image.
Posted on May 26, 2010
Help w/ quantaray 10.4 digital picture frame
pls backup ur data & reformat ur sd card to fat 32 using ur pc
Jan 05, 2014 | Quantaray Photography
Stock No. 81-166-0331 Quantaray 7" Digital
My picture frame works with the slower cards only. My game camera only works with the faster chip. Now that you know what it works with, buy a 2.0 of higher capacity. I am pretty sure you cannot make it work with the faster card.
Dec 14, 2017 | Quantaray 7-Inch Digital Picture Frame -...
Quantaray QTB-9500A with Canon Xsi not working properly
This is probably way too late for the original asker, but the previous answer is incorrect.
The Quantaray QTB-9500A is in reality a ProMaster FTD-5700 and was designed for use with later model electronic 35mm AF models (using the correct dedication module).
As such, the trigger voltage is no higher than 5v making it safe for use on later digital SLR's.
The original answerer is clearly aware that high trigger voltages on flashes designed for earlier, mostly mechanical, 35mm film cameras are often harmful to later models, but you need not worry about your model.
Please take a moment to rate my answer.
Aug 30, 2009 | Quantaray QTB-9500A TTL Flash
Quantaray QDC-NK i TTL Digital Flash Module
The Quantaray Digital NK Module has a small tab on the side of the raised boss that the 8 pins sit on that prevents it from mounting on the QTB-9500A. It's intentional- the NK Digital Module is made for newer Quantaray flashes only. You'll need the older-style AF NK Module to attach to the QTB-9500A.
Apr 06, 2009 | Quantaray QDC-NK i TTL Digital Flash...
Customer service to help me to use quantaray by sunpak
Dec 31, 2008 | Quantaray 7-Inch Digital Picture Frame -...
This is not designed to plug into your computer. The device has no memory to store photos or music. You have to copy your photos onto a USB thumb drive or a NON SD memory card.
Feb 14, 2008 | Computers & Internet
Quantaray 7-Inch Digital Picture Frame  - View your photos right from your memory car...  Logo
188 people viewed this question
Top Quantaray Photography Experts
JP Services
JP Services
jd83854
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
