Question about Samsung Refrigerators
How much oil does a 1/4 hp compressor motor take
  • 121 Answers
Is it hermetic closed compressor? if it is you do not have change oil.
if it is half hermetic and have freon also not change,
if it is air compressor then change oil after 500 hours,use oil especially for compressors,not recommended to use motor oil.
Posted on Feb 22, 2009
What type oil for model 90234 4 HP 10 gallon
The model number is not enough info but assuming it's a run of the mill, Home Depot or Craftsman type electric air compressor, you need to buy compressor pump oil at Wal Mart or an auto parts store. Please don't use Automotive motor oil because that's not going to withstand the heat of your compressor pump and you'll be buying a new compressor because of it. If your compressor has a gasoline, 4 Hp. motor, it needs Mobil 1 synthetic and change it after every 30 hours of operation.
May 19, 2017 | HP Air Tools & Compressors
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    I have an Ingersoll Rand 80 gallon, 5 hp compressor. The motor recently burned up and I replaced it with a new one about 1 1/2 weeks ago. The new motor now has burned up also. Could there be a problem with...
    Yes it could be running (turning) hard which will make the motor pull high amps. If you installa new motor make sure to check the amps while running to be sure that the draw is not over the name plate spec. Could also be that you just got a bad motor... believe me it happens more often then you would think...
    I am assuming that you have checked the oil in the compressor and that the level is okay...
    Heatman101
    Feb 26, 2010 | Ingersoll Rand Compressors 5-HP,...
    IR 2475E Wont start up 220 everywhere No LOP switch
    did you check for a motor reset button on the motor??
    Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
    I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
    from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
    Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
    Missing plug
    On top of the motor. Are you sure it's on top of the motor or could you mean pump? There are two parts to a compressor electric or gas motor and the pump. Although the two are combine in small compressors they are still separate components.
    You said it may be related to the oil plug correct?
    Most compressors between 1/2 hp to 2hp come in two flavors. The first is oil less the second has an oil reservoir. For the latter the oil plug does double duty as the crankcase breather and the oil fill opening. If the opening where your missing nub was located leads down into the crank case it's most likely the oil cap. If that's the case then you need to replace it with a comparable oil breather cap. It can also be a real mess if you start a compressor without the breather in place.
    So is your compressor oil less or oil lubricated type?
    If yours is the former, oil less then you will need to include some information (make, model), about the compressor for any additional help.
    So please respond back with that. Thanks.
    Nov 11, 2009 | Air Tools & Compressors
    I have craftsmen 7gal 1 hp-looks like very low oil level and no motor starts-just momentarily noise and stops?
    1.If it has a low oil level, have it refilled to proper level,
    and restart.
    2.If it does not start. Isolate the motor from the
    compressor, by removing the v-belt.
    3. In this manner, we will know where's the trouble.
    4. Put power to the motor, and have it started.
    5. If the motor start, then it is okey. If the motor
    just groan and does not start, check the starting
    capacitor, it may need replacement.
    6. Check the compressor if it can be turned (one to
    two full turns). If it can turned, then, it is okey.
    Otherwise, check the compressor piston rings.
    It may need to be replaced.
    7. Reassemble your compressor and replace the
    v-belts.
    8. Then, you can plug in to the nearest power outlet
    and start the compressor.
    Nov 01, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
    Craftsman 1/3 hp compressor leaking oil
    most defintly you need a head gasket but you will also need piston rings look up your local sears service center not automotive or the store you want appliance service center
    Jun 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
    YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
    Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Refrigerators Logo
    232 people viewed this question
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
