Question about 3d Rose Londons Times Funny Music Cartoons - Ventriloquism University - Light Switc
Ventrilo 3 stuck at synchronizing, cant connect.
  • 2 more comments
  • Anonymous Mar 11, 2009
    stucks on synchronizing
  • Anonymous Mar 25, 2009
    It didn´t work... what I do then?
  • Anonymous Apr 24, 2009
    Solution #1 didn`t work
  • Anonymous May 18, 2009
    Ventrilo stuck at synchronizing, can't connect.
    same as everyone else. lol
This problem normally appears when using routers and having NAT enabled
To Fix this do the following:
Enable port forwarding to port 3866 UDP and TCP
Posted on Mar 11, 2009
Hello , i have a problem with ventrilo , that i get a MSG"synchorizing when i ress connect , helppp : )
Posted on Feb 27, 2010
Having same issue, unisntalled, reinstalled, system restore, firewall off, added 6100 all NO GO, win7 64bit, was working yesterday nothing changed run a guild others can connect, can be reached at mohawk50@msn.com
Posted on Jun 03, 2011
    Problem Solver:
  • 5 Answers
I got this message when I didn't have a proper firewall configuration - make sure you're allowing vent to connect out on the server port and port 6100 >> allowing 6100 outbound seems to fix the problem.
Check this post out for more info.
Posted on Sep 05, 2010
2 Suggested Answers
  • 5 Answers
SOURCE: my ventrilo is stuck at synchorizing and I uninstalled/installed
check out this link for more information on some network/firewall issues that could be causing your problem.
Iccan not connect my phone with computer i have latest pc suit and i cant connect my phone in any computer
REINSTALL THE PC SUITE THEN SYNCHRONIZE IT WITH PHONE I.E. THE SAME SETTING IN PHONE ,IT HAS OPTION OF SYNCHRONIZING. THE BEST IS YOU USE DATA CABLE FOR CONNECTION
Feb 04, 2011 | Nokia N72 Cellular Phone
Tip
How to back up using Ventrilo
<p>Ventrilo is an application that a web server and you can chat with other registered users. Ventrilo is often used in games will allow players in multiplayer games, real-time interaction. Some users have programmed several Ventrilo server setup on the machine. Ventrilo safe is copying a specific file on the backup device. This ensures that your server settings, copy the file, you do not recover your hard drive. <br /> <p><br /> <p>1. Click the Windows Start button. Click Open "Computer" from an Explorer window. Double-click the C drive to a list of folders on your computer to see. <br /> <p><br /> <p>2. Double-click the Documents and Settings folder. "This is a folder with the profiles and preferences of the user. Each user has a separate folder. The folder is labeled with the user. Double-click your user name in the list of folders. <br /> <p><br /> <p>3. Double click "Application Data", double click on "Ventrilo". This folder is the file "ventrilo2.ini. This includes all settings for Ventrilo. Right click on the file and choose Copy. <br /> <p><br /> <p>4. Click the Windows Start button and click My Computer. Right-click the drive where you want to copy the settings Ventrilo. This may be a CD or DVD, or you can use on an external hard disk. Click "Insert" to back up your settings in Ventrilo to create. <br />
on Jun 22, 2011 | Computers & Internet
How to remove code sc 322
322 C 1st laser synchronization error
• The 1st laser synchronization signal
cannot be detected by the main scan
synchronization detector board even
if the laser diodes are activated.
• Poor cable connection between the
laser synchronization detector board
and the LD unit.
• Laser synchronization detector board
out of position and angle of reflection
not correct
defective
• LD unit defective
Most likley to be polygon mirrow thats faulty.It is inside the lazer unit.If u hear loud winding noise that will point to polygon mirror,or possibly it has seized up and cant turn at all.In any case ull need service engineer to replace it.
Dec 04, 2010 | Ricoh Aficio 1045 Black and White Copier
My ventrilo is stuck at synchorizing and I uninstalled/installed
Aug 23, 2009 | 3d Rose Londons Times Funny Music Cartoons...
Cant connect my HTC touch HD to PC thru activesync
1. Go to the settings.
2. From the options of Personal, System, & Connections, chose connections.
3. Tap on USB to PC icon.
4. Here lies the demon. There is a small box with lengthy explanation line (probably automatically ticked) which says "Enable faster data synchronization" you just need to uncheck it and tap on ok.
Now the activesync will start working.
May 27, 2009 | HTC Touch HD Smartphone
Cant hear but mic works
Ventrilo has an excellent forum system and I am sure you will find an answer there.
Apr 12, 2009 | Logitech ClearChat Pro USB Headset
I cannot connect to port 3997
I would first try to connect to other ventrilo servers on other ports. Make sure it's not your vent program. Next I would make sure you are not having issue with your windows firewall or a third-party firewall (Symantec/Norton/McAfee etc). Disable them temporarily to test. Because you can not connect via telnet tells me something is blocking your port. How about the router/firewall? Is it new? If so, try replacing it with a known good one.
Jan 31, 2009 | Computers & Internet
I cant synchronize my HTC HD with windows vista business. i am receiving error message saying that synchronization cant be on windows vista. Any solution?
Hey
I had that problem too and that's the Windows Mobile problem.
Go on your Touch HD to: Start -> Settings -> Connections -> USB to PC -> and check Active Sync (synchronize with Outlook) and clear the checkbox "Enable faster data synchronization" and tap OK in the right screen corner.
You don't have to restart your device.
I think that this should help.
Cheers,
Sz.
Jan 15, 2009 | HTC Touch HD Smartphone
Outlook synchronization with LG mobile sync
LG Outlook Sync is a utility to synchronize your MS Outlook data with your LG devices. The current LG Outlook Sync supports enV 3(VX9200) and enV Touch(VX11000) only. LG Outlook Sync does not support old LG devices. *
Oct 28, 2008 | LG RUMOR Cellular Phone
Headset paired but doesnt function in ventrilo
Did you ever figure out what was wrong. Mine is doing the same with my LG shine. I will have to take it in for service. You had the problem quite awhile ago. Hoping you got an answer.
Oct 24, 2007 | Jabra BT125 Headset
3d Rose Londons Times Funny Music Cartoons - Ventriloquism University - Light Switc Logo
19,833 people viewed this question
Top 3d Rose Electrical Supplies Experts
Ronald Prier
Craig Butler
Craig Butler
Are you a 3d Rose Electrical Supply Expert? Answer questions, earn points and help others
