The vertical lines come and go,but the horizontal stay. The lines are about 1/2 inche wideand different colors.The whole screen is covered with small squares.
• Do not put the TV near extremely hot, cold, humid or dusty places.
• Do not put the TV near appliances that create magnetic fields.
• Keep the ventilation openings clear.
• Do not place the TV on a rough and slanted surface, such as cloth or paper.
• Never open the cabinet or touch the parts inside.
• Wipe your TV with a clean, dry cloth. Never use water, cleaning fluids, wax, or chemicals.
• Do not put heavy objects on top of the cabinet.
If your TV was moved from a cold to a warm place, unplug the power cord for at least two
hours so that moisture that may have formed inside the unit can dry completely.
These are the 8 Causes that contribute to a serious display malfunction with in this set. if you have found yourself committing any of the 8 causes for immediate malfunctions that can occur with this High efficiency plasma tv, you may have damaged its internal circuitry.
Here are some results of damage occurring due to any infraction of the above precautions.
1. Minor/major board malfunction.(ic,resitors,capasitors,pcb main, input block failure, etc..)
2. Control board malfunction
3. Short circuit.
4. Power board burn out.
i suspect a logic break down with in the input section on the main board. please check to see if there are any lose input sockets that may be shorting the transfer of clear video. check all input sections for break points.
Its the main board problem as the capacitor on the board is faulty for sure .its on its last stage to be get blown off.so its quite advisable to get it replaced by checking out with meter the faulty one. to avoid the further damage do not use the tv till it get repaired otherwise it will also damage some more parts.
This is a qualified TV tech job to rectify problem in your plasma TV.
It can not be done by remote assistance over internet.
Please call Samsung service.
Thank you for choosing Fixya.com..
it seems that the picture tube a small paart of Tv that engaging to the image of the Display are damage.
In this case we do not have any solution to fix we can try to ask a technician if he have some spare parts for our TV.
but if he has noyhing it is advisable to buy a new unit or change it permanently.
check the connection from the tv.
also try testing the unit using a dvd player or a vcr.
let me know if those lines was not seen.
Looks like a bad Video Processor chip. Have you tried the Sansung Service centre?
I have a Samsung HP-S4253 It has 5 vertical lines about 1/2 inche wide .Also 8 vertical lines but smaller.All are different colors.
I have a Samsung HPS253 It has 5 horizonal lines about 1/2inche wide all different colors the same with vertical lines. The whole screen is covered with small squares.
Samsung HP5253 with horizonal and vertical lines that come and go.I checked all the cables they were ok.When i use the dvd plyer there is more lines.
Yes
