Question about Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat
Rheem tanless waterheater cuts of with error code c4 then 13.
Enviro plumbing, Irving tx. thought the problem to be the absence of the condensation tee; installed and did not solve problem.
  • 2 more comments
  • tommy_powers Feb 24, 2009
    Vented straight up,
    Error codes C4 and 13, cuts off. Resets ok,, just a pain.
    Installed about 2001, prior home owner,.
    Had two tank types, removed both, replaced with 1,, propane, Installed in attic. Water volume does not appear to be the problem.
    Will have gas pressure validated.
    Thanks
    These hints have been tried... next is to check propane pressure.
    thanks, anyway
    tp
  • rts1229 Mar 02, 2009
    I have a similar problem. I have had to reset three times in the last week, with error C7 21 yesterday, and now C8 21 today.
    I have a 90 degree coming out of the top for about 18 inches, then straight up for about 4 feet. No problems until this week. Natural Gas, and all other home appliances are working fine. In addition, I have a second unit on other side of house working fine.
  • Scott Magill May 11, 2010
    What is the error code that it gives you? How is it vented up and out or does it go straight up? How installed and when? What kind of water heater did you have before? I would check gas line to make sure it is sized right
    Scholar:
    New Friend:
  • 70 Answers
Air intake of the unit and or vent termination may be blocked. If the heater worked for that long without a condensate tee. The heat exchanger could be pluged . I would have heater cleaned and have them check out heat exchanger.If you want to take flue pipe off of the top of water heater you can take a flashlight and look down at heat exchanger to see if it is pluged take front panel off first also turn power off if you decide to do this. If you need any help let me know
Posted on Feb 24, 2009
Need to know the year of my tank RR410T
the age of all water heaters is listed under the serial #, not model #. you will have to call a plumbing supply house that deals in your brand of waterheater, a.o. smith, ruud, bradfordwhite,etc.
Mar 02, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Sep 14, 2011 | Rheem Tankless Hot Water Heater...
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Rheem rtg-74pvn-2 tankless water heater installed in 03/09. Intermittently the hot water stops when only the hot water tap is on. No error codes appear. Bill W.
Before calling service technician, open following links for resources including Rheem chat and possible manual:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Crossover.html
Typical tankless manual says to have yearly service which includes checking household plumbing, gas supply, vent and condensation, check sensors for loose wires, clean and inspect burner parts and ignition factors etc.
Aug 04, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem rtg-53pvn will not turn on and heat water when hot water is turned on - no error code - remote just goes off like the power is off
Before calling service technician, open following link for Rheem troubleshooting resources including Rheem chat:
Rheem will suggest you catch up on required yearly maintenance which would cover most causes for common error codes, and cover cause of no error code including plumbing problem or loose wire or PC board failure. Combination of problems can also cause failure and these issues would be covered by general maintenance.
Solve most tankless problems same day for $350
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Jul 21, 2011 | Rheem RTG-53PVN Indoor Natural Gas...
Every time it rains our instantanious hot water system comes up with error C9 and C12
Before calling service technician, open following link for Rheem troubleshooting resources including contact and chat and typical manuals:
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Error codes are start points for troubleshooting and can include long list of things including multiple causes.
Error code 12 shows 'condensation collar' and 'vent lengths' which are associated with the vent to outdoors. Changes in air pressure during low-pressure rain events MIGHT affect the venting and cause tankless not to ignite, and MIGHT cause excessive condensation. Improper condensation can rust out the heat exchanger without showing any signs of problem until the unit is ruined.
C9 is not listed. Contact Rheem, and then add a comment saying what Rheem suggests as solution for C9 error. This will help others in the community with same-similar problem.
Instruction manual recommends yearly maintenance by qualified service technician.
This maintenance would usually check all things shown in error 12.
Jul 18, 2011 | Rheem Tankless Hot Water Heater...
Intermitant failure of waterheater to turn on when demand is created, then at other times there's no problem. lately it fails to resond more than it works.
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 27, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat Logo
1,514 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Mike Cairns
Mike Cairns
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
