Question about Mitsubishi WS-55859 55" Rear Projection Television
No Audio with HDTV on Mitsubishi WS 55859; no problem w analog tv
We have a rooftop antenna for our TV until now we have been content to use the Analog TV for our viewing. Now with the switch to HDTV we need to prepare to use the digital version. We have clear video but no audio. Any suggestions?
  • Kathryn Bolton Feb 22, 2009
    we don't need a converter box... the tv is hd already... ?
    thanks for trying! :)
    Sergeant:
  • 227 Answers
Have had bad exprience with RCA converter boxes. The box will lose audio and has to be turned off and then back on. You may want to hit mute during this process, the volume varies from analog to DTV. If you have no problem with analog audio I would look into a different converter box.
Posted on Feb 22, 2009
  • Mike Schmidt
    Mike Schmidt Feb 22, 2009
    As I read your info HD ready is HIGH DEFINITION not Digital. I misunderstood that you were using a digital box, sorry.
Ws 55859 has audio but picture is black
This unit does not have a lamp, but 3 CRT's. Odds of all three tubes failing at once is very remote. I would look at the voltages that run to your CRT boards and see if they are low or have a load. You should also check your circuit boards on the bottom of set to see if the CRT's have been leaking glycol. If the board looks wet ot corroded, you are dead in the water.
Mar 20, 2013 | Mitsubishi WS-55859 55" Rear Projection...
There is not reception. Antenna A failed a year a go, I switched to Antenna B and now is not working either. When I connect Cable (COX) antenna inputs, A & B, do not detect it. My TV is a Mitsubishi...
Check if the video /audio input( AV) works ok.If so the tuner inthe set is defective and must be replaced.
please replace one to confirm after checking the +B voltage on the tuner being present.
Sep 12, 2010 | Mitsubishi WS-65513 65" Rear Projection...
I have a Mitsubishi WS- 55859 projection screen tv and the screen/lamp flashes on and off a couple of times then lamp go off but you can still hear static.The TV is on but not picture is getting to the...
The WS-55859 does not have a "Lamp" it is a 2001 rear projection set with three picture tubes.
Have (if this is the correct model) you tried the self check this set has?
Also do you have this problem on all inputs--tuner, and various rear inputs?
The more you tell me the better I can help you.
Got a IM?
SD TECH
Feb 23, 2010 | Mitsubishi WS-55859 55" Rear Projection...
My mitsubishi TV ws-55859 does not turn on. The green timer light comes on and goes off after 3-4 seconds but tv does not turn on. What could be the problem? Help please......
Poor solder connection and Bad STK ICs 2 of them replace Both Big Black IC will have part number on them Call Mats for STK 1-800-628-1118 example
STK392-570.
Nov 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi ws-55859 parts
time to get a new one.
even you get the main board, you might have other problem that has not show up yet.
Oct 05, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is smartin38@verizon.net
Sep 11, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Tv wont turn on
ok is in shut down mode kine of proteccion some of the fuses are pico fuses but you may have problem with convergence IC's that what I' check first if that is ok go to HVT .. if U still have problems e-mail me
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859
Check any/all fuse devices in power supply.Let me know.....T.
By the way,the tv serial # is 107543. I assume the model # is
as stated==WS-55859.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
