Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Honeywell True Steam heats but continuosly drains / vibrates
I installed a Honeywell True Steam 9 gallon humidifier a few months ago with the standard manual humidistat. It's worked fine since we found the sweet spot in our house, which turned out to be high...around 55...house isn't very tight and unit is at the upper limit size-wise to support our square footage, around 3,100 sqft. Anyhow, it seems to be contsantly draining now as case and drain line are always extremely hot, and the supply line with in-line filter is vibrating every few minutes whenever it is refilling the tank, which is constantly because it's continually draining. This condition is obviously wrong and not only am I hearing the vibration in the house, but am also sending good water down the drain without the benefit of it humidifying the house, I believe.Any help or advice would be greatly appreciated. No fault lights are illuminated and the "power" and "humidifying" LEDs are lit. Thanks!!!Dave
  • bradwr Apr 15, 2009
    I have had the exact same problem with a 6 gallon and a 12 gallon Honeywell TrueSteam humidifier. It works fine for a few weeks, goes through a few auto drain cycles and then starts draining constantly 24/7 while it is still humidifying.
Easy one gentlemen! The problem is the water and the **** in it. The **** builds up inside the valve and doesn't allow it to work properly. This is how you fix it: - remove the solenoid. It is quick: remove the 2 hoses and pull out the 4 wire plug. Take the solenoid in your kitchen. - the valve has 3 ports: one @ top (port A), one at the bottom (port B) and one large, with a little filter in it, where you have to push the locking mechanism in every time you re-install the water reservoir. This woulb be port C. Pour a few drops of CLR into port C. The CLR will drain down. Re-fill a few times, then wash with water. Take a small flat screwdriver, put it into port C and try to move the little black plunger / piston inside the valve. Move it as much as you can, in and out. That little plunger gets sucket into the valve by the electric coil every time the valve is energized. When power is off (de-energized), the plunger is supposed to seal back. If **** gets in, it will not seat properly, so try to rub the sealing surface (seat) with a small screwdriver. Repeat the wash cycle w/ CLR. - cut the 2 wiresgoing to the solenoid and try to rig something safe: connect the 2 wires to a small extension cord and use lots of tape to insulate the wires but also to secure them in place. Energize and de-energize the solenoid many times. The coils are 120 vac. You shouls see the little plunger moving in and out freely. Disconnect, clean again, etc. try not to kill yourself by electrocuting with 120 and water and some unsafe grerry-rigging ... - re-install it all and should be fine now. Good luck! Eugen -
Posted on Oct 28, 2012
I had the same problem.
I replaced the solenoid which resulted with the same problem.
I then blocked the drain using a ball valve, that resulted in the humidifier overflowing.
I do have a fault code (3 blinks) indicating failure to fill tank.
However, if this were true, blocking the drain would have solved this problem.
I have replaced the unit with a new one, and it is now working perfectly.
If you have covered all these bases then I suggest replacing your unit. Hopefully it's under warranty.
Cheers, Rich
Posted on Jan 20, 2010
Scale build up on heating element
Try white vinegar instead. The same type of scale builds up in drip coffee makers. Most recommend white vinegar to remove the scale that builds up over time. The added bonus is it costs less and is completely safe. If your unit is a water over paper media humidifier, you would be much easier to replace the paper media.
Sep 12, 2012 | Honeywell HM509DG115 120V TrueSTEAM...
I need the operation manual for the Honeywell quick steam humidifier HWM335, 3 gal. please
Here is a link to your Owners Manual that you can download and print. Please do not lose it, as this model has been discontinued by Honeywell.
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/QuickSteam-OwnersManual.pdf
Mar 23, 2011 | Honeywell QuickSteam HWM335 3 Gallon...
True Steam Direct Injection Model # HM506 service light blinks 6 times before remaining a solid color. What does that mean? I realise that the unit is detecting a system fault, would just like to know...
Remove and clean the water level sensor and see if this resolves your error. If cleaning doesn't do it, check the connector for buildup. If neither of the above works, you'll need to order a new sensor - I've gone through two in four years as the heat appears to crack the plastic housing, allowing water to wick up between the plastic and the contact, ultimately shorting it.
Feb 21, 2011 | Honeywell Power Humidifier: Furnace...
Honeywell HWM 450
I found a solution to our problem with the fill cap failing/leaking. It was/is not the cap, it’s the gasket/grommet/o-ring. Remember “THE MAGIC BULLET”, well the gasket, that’s where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
SEE EBAY: NEW AUTHENTIC MAGIC BULLET 4 REPLACEMENT GASKETS SEALS
Dec 31, 2009 | Honeywell HWM-450 4 Gallon Humidifier
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
Aprilaire 500 - Everything works, but humidity will not increase!
You should take out that aprilaire and throw it in the garbage or return it to who you got it from. Ask them why they didn't offer you the best humidifiers available. The only way to truly control humidity in your home without running your heat is a steam humidifier. Autoflo makes a good one also honeywell makes a new one. I have installed a honeywell tru steam in my own home and a few customers it hasn't lived up to its advertising. The auto flo has never given me any problems with customers.
Dec 18, 2008 | Aprilaire 600 Humidifier
Honeywell True Steam Humidifier
Yes you will want the out door sensor. The reason why is it is going to read the average temp outside and will adjust what you hum is producing due to the temp outside, that is so you dont cause condensation on your window. You can run it in manuel or auto but i would strongly reccomend to run it in auto.
Jul 02, 2008 | Honeywell Power Humidifier: Furnace...
HE440A Steam Power Humidifier
The most common cause of overflow is when hard water deposits build up and prevent the float from closing. You'll have to open up the unit, make sure there's no water in it, and clean out any mineral deposits.
The problem with these steam producing units is that there is no built in way to remove those deposits automatically. The water comes in, evaporates, and leaves anything else that was suspended in it behind.
Nov 14, 2007 | Honeywell HE440A1005 Humidifier
Honeywell HE440A steam power humidifier
Honeywell has had lots of problems with this humidifier. They are coming out with a completely redesigned steam humidifier that will be available in a month or two. If you know who installed it (through equipment stickers and such) you can probably get them to swap your old trouble prone unit for the new design for just the labor. If they won't, then push them to talk with their Honeywell distributor about it.
The problem is most likely a stuck float in the humidifier. There are two floats that run up and down. One that tells it when to add water, and one that is a safety. They both tend to get stuck with mineral deposits.
You can fix it by unplugging the humidifier, turning off the water, draining the pan (unscrew the drain on the bottom a few turns), disconnecting the water lines and wires (2 molded plugs and 2 screw terminals-don't worry about if they get swapped). There should be a couple of screws that lock it into the ductwork such that when you remove the screws you can pull the whole unit out to see inside the water tank. Then just clean everything out well and put it back together in the same order.
You really do want Honeywell to get you a new humidifier though.
Humidifiers Logo
1,438 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Ken Thomas
Soulvisitor
Soulvisitor
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
