Question about Maytag MMV5207AAS Microwave Oven
Is it safe to heat our food without any cover in the microwave?
  • 333 Answers
Yes it is perfectly safe to heat food without a cover. It is the microwave that cooks the food from the inside out and it does not leave any radiant behind. I hope this helps. Don't forget to rate my answer.
Posted on Feb 22, 2009
Kenmore microwave oven doesn't heat food. I had
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jan 24, 2013 | Microwave Ovens
No heat when microwave in use
Jan 11, 2013 | Microwave Ovens
A sort of whistling sound is coming from my microwave oven when it is working.The food is getting heated up properly without any issues.
If there is noise please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground with a hiss.Also if stored it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Now keeping clear switch on , use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type. Also check the wave gudie within the cabin for dirt of food accumulation, wipe clean and dry.
If there is heating without any issues , you can use the microwave safely.
Sep 12, 2011 | LG Microwave Ovens
Has power but it does not heat up food items
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had depositedthen it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
Sep 03, 2011 | Whirlpool GH5176XPS Microwave Oven
Everything fonctions on my microwave but it doesn't produce heat. Is it the magnatron? If so, what cost might I expect? Thanx. Brian
Jul 08, 2011 | Microwave Ovens
SER#MH117OXSB-6 1000 WATTS I PUT SOMETHING IN TO HEAT UP AND IT MADE A LOUD SHARP POP.. IT RUNS BUT NO HEAT
Jul 07, 2011 | Whirlpool Microwave Ovens
I covered the plate with 'heavy duty aluminum foil' thinking it was safe for for microwave use, then I saw a sparkle inside while turning. I stopped it, took off the aluminum cover, turned the microwave...
The food is safe as long as the food has not got oxidized aluminium on it.
Microwave energy is very high and will melt metals!
As long as it is not arcing any more there should be no problem.
Jan 03, 2011 | LG Microwave Ovens
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
Ge Microwave space saver over range working but
It is a good possibility that the stirrer has failed. In the top of cabinet is a round cover,there is a small round plug in the edge of it,pry plug out and put it in safe place,rotate the cover < twist locks > gently let it down and stirrer will be either setting on cover or still attached. If you notice any damage< it is a round aluminum disc that is flat > then you need a new one. If you don't see any damage put it back in < put in hole and turn until you feel it line up with shaft and push into place,< gently >.Make note of position and put cover back on < stirrer does not lock on shaft so you have to hold it up until you get cover under it in most cases. Run a short cycle and remove cover to see if it turned at all. If not the motor is bad < turns stirrer during operation>. This is the first time that question has been asked of me and it is the only thing that I can think of if it heats glass and not food.
Apr 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-202EW microwave croaking- roller needs replacing?
You could remove the new turntable support but without replacing it (part # FROLPA101WRKZ) you just won't get even heating.
One option might be to remove the support, place in another (larger) glass tray or other microwave safe plate upside-down, then put the existing tray on top of that.
That will raise the food up. Then be sure you don;t place the food in the center. It will heat better if it's a little left of center.
Nov 04, 2008 | Sharp R-202EW Microwave Oven
Maytag MMV5207AAS Microwave Oven Logo
110 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
