Question about Haier HWD1000
Haier washer the water goes in and goes straight out through the drum into waste pipe
    Problem Solver:
  • 8 Answers
There is an exit hose behind the machine. This hose should be approx 3 feet above ground level, you may find a water mark behind the machine; then it goes down into the sink or standpipe in the wall. This hose holds the water, your pump pumps it over the height as & when required; the hose is never let loose at floor level.
Posted on Feb 22, 2009
Drum won't fill model #XQG50-11
check that your drain pipe is looped above the height of the drum.
if its lying too low to the floor, it will act like a syphon
May 08, 2014 | Haier Washing Machines
Septic vs washout tub?
Waste water from the washer is not pumped out but rather is gravity fed down the drain. You cannot drain the water up higher than the washing machine's drain outlet. You would have to cut into the drain pipe - below the level of your washer's drain outlet - and put in a T that will tie into the drain pipe and allow for some type of connection to be made from your washer's drain hose.
Mar 23, 2014 | Washing Machines
Water running through. lights flashing
If machine has just been installed check that the height of the outlet pipe is higher then the level of the drum otherwise the water will siphon out.
Dec 29, 2012 | Hoover Washing Machines
Hi there, my machine won't fill up, but is instead draining. The water is coming out of the waste pipe, instead of filling the drum!
Would your waste pipe be too low OR do you have drain pipe taped tight to waste pipe that can cause siphen..Note waste pipe should be as high as the back of the washer and held in pipe but not taped so no air can get it..If I helped you please vote if you need more help please ask...and good luck
Feb 05, 2011 | Washing Machines
Water goes in then straight out of the waste pipe
The waste pipe is probably too low, this is letting the water syphon out.
Try lifting the outlet pipe higher up, this should solve the prob.
There is a line on the back of the washer, which incates the min hieght for drain outlet.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
ODOR IN WASHER
Are you wiping the glass and the water seal (you have to peel it back to get at the pooled water) each and every load? We used to have a top-load and never had to do this before, but if you dry it every time it won't mildew.
If you weren't you will have to wash the rubber gasket with vinegar or some other solvent... Check your owner's guide.
May 20, 2009 | LG WM-2277HW Front Load Washer
Stegnant water smell
It should completely empty the m/c.
If it is plumbed into your sink waste this could be cause of smell, also if it is connected to your waste make sure the hose is above the bottom of the sink trap,as water can sometimes syphon back into the washer from the sink. Remove hose from sink connection and clean and check for obstruction.
I doubt your pump is faulty.
If it goes into a stand pipe make sure this is not partially blocked, and again clean stand pipe with a strong disinfectant or similar
Plz rate my solution.
Thanks.
Dec 21, 2008 | Hotpoint VVSR1070D Top Load Washer
Haier front loader 1400 spin
check to see that pump is not blocked stopping water getting away quick enough
Mar 16, 2008 | Haier XQ8M22-C PORTABLE TOP LOAD WASHER
Hotpoint wf860 - H2O Error Code - Machine is asking for water but draining it straight out
Check that your outlet pipe rises above the stated height on the back of the machine (about 3/4 of the way up). If it is too low, it will siphon the water out of the drum. If you're not sure what height it should be at, raise the top of the pipe (ie where it bends back into the outflow pipe) above the top of the machine (if you have room) or as high as you can. It must be above the height of the drum.
Good Luck
Jan 06, 2008 | Hotpoint Ultima WF860 Front Load Washer
Haier HWD1000 Logo
78 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
