Question about Sylvania LC420SS8 LCD TV
When my 42 inch sylvania is turned off. Model number LC420SS8, it makes a buzzing sound. I'm not sure it could be the tv because i have only had it for less than 3 months. When it is turned back on, it works fine, its only when it is turned off.
  • 265 Answers
I have to LCD TV's and mine does this aswel so its nothing to worry about.
I know how irrating it can be, as i have one in my bedroom and you can hear it when your trying to sleep.
But honestly theres nothing wrong with it, they all do it, its to do with the power!
Please Rate.
Thanks
Posted on Feb 22, 2009
Green light flashes back red
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Sylvania LC420SS8 LCD TV
Sylvania LC420SS8 LCD TV When i turn on tv it turns off with in seconds
Seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Sylvania LC420SS8 LCD TV
I have no problem, I just want a sylvania owners manual for TV, model#6626lct J dec 2006, I misplaced mine. thank you
This seems to be it, hope this helps
http://www.manualnguide.com/download/manual-guide/sylvania-lc420ss8-owners-manual.html
Mar 14, 2011 | Sylvania LC420SS8 LCD TV
I have a usb port and I want to watch nexflex can
Hi - No, that would not be how to set it up (It wouldn't work) You would plug a VGA cable like the one most likely plugged into your monitor (15 pin connector on each end) from your PC video card (this is with both machines powered off) into the VGA port which you have on the TV.
With the PC on turn on the TV and with the remote select your source (would be called VGA or PC) and there would be your PC display on the TV. Bring up your browser and login to Netflix. The sound would come through your PC speaker and you would be watching movies on your 42 inch display.
Enjoy, Mikeywaf
Mar 08, 2011 | Sylvania LC420SS8 LCD TV
My lc420ss8 sylvania tv will not work with comcast remote what are the codes I can use?
Because there are so many remotes for Comcast products I am not sure which code(s) is for you, so try this site:www.remotecodelist.com
Good Luck !
Feb 11, 2010 | Sylvania LC420SS8 LCD TV
A black box keeps popping up on my new 42 inch flat screen.
Turn off Pip 0r turn off closed caption, in manual.
please rate!
Jul 10, 2009 | Sylvania LC420SS8 LCD TV
Need remote code for LC420SS8
SEARCHING FOR YOUR CODE
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
Turn on your TV.
On the remote control, press TV once. Then press and hold Setup until the key blinks twice, then release Setup.
Enter 9 - 9 - 1- 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device.
Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
Press Setup once to lock in the code. The TV key will blink twice.
To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the auxiliary device you are searching for.
Apr 05, 2009 | Sylvania LC420SS8 LCD TV
Sylvania lc420ss8 lcd turned off wont turn back on
Simply unplug the set, let it sit for a minute or so, then plug it back in and turn it on. I had a similar problem with the same TV and it is working fine now.
Jan 01, 2009 | Sylvania LC420SS8 LCD TV
Remote code for Sylvania LC420SS8
Hello frozen thank you for using FixYa.com for your answer my name is David.
Well I had to do a little bit of a search but one of these codes should help you out.
Sylvania 506, 525, 536, 566,
568, 569, 573, 600,
610, 652, 654, 656,
659, 660, 664, 665,
666, 671, 672, 674,
677, 723, 724, 729,733
I retrieved these from the following link that help you again in the future
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/IR-to-UHFProUpgradeKit132327.pdf
thank you again for choosing fixYa.com for your answers.
Nov 08, 2008 | Sylvania LC320SL8 Television
Sylvania LC420SS8 LCD TV Logo
261 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
