Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Door that opens the filter basket gets stuck!!
Same type of issue except the door to the filter basket gets stuck. I think the problem is with the fine grinds getting stuck in the part that slides the basket in and out. Any suggestions? AFter reviewing the problems some people experienced when removing the whole component, it seems like it would be a pain to reinsert.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I bought one at a thrift store for $8.00 and it had the same problem. All I did was put some cooking vegetable oil on the open basket door where it stuck, using a q-tip. It has worked great for over a year now.
gramma5
Posted on Mar 20, 2009
"Sucking" noise
check skimmer basket
May 04, 2012 | Hayward Pool & Spa
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
Rear pontiac grand am door stuck
I have a 2002 pontiac grand am with both power windows and door locks. Everything else works except the lock assembly on the rear driver side rear door latch. I have removed the inside panel , aboth rods are connected. all power is disconnected to that door. I moved both of the rods correctly and the door will slightly open but that is all. How can I get it to release so I can repair or replace the latch and lock if nescessary ? I had the same problem only reversed with the frond door it would not close but after some trying I fixed that problem.
Apr 04, 2012 | Pontiac Grand Am Cars & Trucks
Our Samsung J1455AV door won't open, just over a year old. Have cleaned the filter, re-run a cycle, turned off at wall. Help!
Hi
Thanks for using FixYa. To start with if the door lock is stuck and wont unlock then you can pry it to open, and just don’t try too hard. The issue can be with the door latch that is stuck, to unlock it you can stick a flat screw driver behind the door latch and then lever it to open so that you don’t have to pry it to open. Once it’s done, please make sure to replace the door latch assembly to avoid any further issues. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 12, 2010 | Washing Machines
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Soap looks like its mostly still in soap bay when cycle is done.
There are several possible causes for this problem. Start the dishwater and listen for the opening of the soap dispenser. It should open just after the pre-rinse (depending on make and model). You should hear an obvious click when the door opens. If it opens too late, this could be a control timer issue.
The door could also be getting stuck against another object (basket for instance). Yet, another cause may be a clogged or defective pump. This can be checked by bypassing the door sensor switch (I use a pencil). Close the door almost all the way (or expect a very wet kitchen). Start the machine and observe the water flow. It should be very powerful and should hit all surfaces. If it is trickling out, you probably have a pump problem.
Jul 31, 2009 | Maytag Dishwashers
Filter Basket pops open while grinding and brewing
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
Jul 14, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Door to filter basket won't stay closed
had same problem..i took the basket holder and door off and gave the basket slider a good cleaning along with other internal parts. now works fine
Oct 30, 2008 | Cuisinart DGB-600 Coffee Maker
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
369 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
