Question about HP Computers & Internet
My daughters HP pavilion boots with an exception breakpoint. I tried to boot in safe mode and got a Run-time error, 10050 Network subsystem failed, I don't know what she's done to it, any ideas?
  • 70 Answers
You probaly just have a broken program in your startup programs and with the "exception breakpoint" error I would guess it's java based.
Try this:
To get to startup programs go
Start -> Run -> In the box type "msconfig" and press enter -> Press the startup tab -> and look for any software that may be causing the problem and disable.
Hope this helps.
Sean
Posted on Feb 22, 2009
Won't boot disk light steady on
unplug and wait a min. or so, plug in, try again. if that fails, reboot, try a system restore/recovery. If that fails, boot to safe mode with networking, download MALWAREBYTES freeware at : http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, DELETE ALL RESULTS, REBOOT. For further assistance respond to this post.
Dec 23, 2012 | HP Pavilion a450n PC Desktop
Hp pavilion a4311f, hp support assistant still frozen and 'a error occured'
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Apr 17, 2012 | HP Computers & Internet
Will not boot in to windows keep reseting error. 100a biohd -8 hd535-3 hd535-6 hd521-4 hd521-2
boot your laptop in safe mode by pressing F8 while starting the computer. follow this link http://download.bleepingcomputer.com/malwarebytes/mbam-setup-1.51.1.1800. download and install antimalwarebyte while in safe mode. Run a complete scan, restart the laptop, update your antivirus and do a complete scan and you will be good. If your laptop restarts when trying to boot into safe mode, then you need to repair your Operating system with its original disk. This would solve your problem. Please give me a feedback
Aug 09, 2011 | HP Pavilion Elite m9515y PC Desktop
Isass.exe application error -- Downloading data
Have you tried a safe boot up on the computer that you say will not boot. ON startup press F8 and see if you can start a safe mode. It will allow you to run some programs on safe mode.
Mar 24, 2010 | HP Pavilion dv6000z Notebook
HP Pavilion dv9207us PC Notebook Will not boot... keeps looping through diagnostics. Will not boot to recovery desk stating "an instruction at ### bla-bla reference mem at ### bla-bla. Memory could not be...
It sounds like a malware that corrupted the system. Try booting into safe mode. That way it runs a very reduced amount of programs and processes so that it won't run into that error you are receiving. In safe mode, you can scan your system for malwares. Once your machine is clean, and the error still persists, it could be a disk error that the malwares left behind. So run the disk checking utility. If the problem still persists after that, then you'll need to do a repair (partial) install of the OS by booting from the Windows disc. That last option is also valid if you cannot boot to safe mode. If any of my suggestions work, please do rate me. Thanks and good luck. Hope it all goes well for you.
Feb 13, 2010 | HP Pavilion dv9207us PC Notebook
HOW DO I TAKE MY HP PAVILION DV6000 OFF OF SAFE MODE. BECAUSE THE PC CUT OFF CAUSE OF LOW BATTERY. I JUST WANT PC TO BE BACK IN REGULAR MODE NOT SAFE MODE
You should just have to shut it down in safe mode and reboot. And it should come up in normal mode. You can try hitting F8 when you turn it on until you get the boot menu and then select boot in normal mode.
If it keep wanting to go into safe mode it may need to reboto a few times to clear out something before it behaves but it should boot into normal mode on its own.
Oct 24, 2009 | HP Pavilion dv6000z Notebook
My computer is not booting up.
Try this,Start in VGA mode.Once started,update your video drivers and do a virus scan
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Jan 15, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Error : loading operating system
plz try to boot in safe mode run check disk and then boot normally, if the problem arises then try by repairing the operating system. plz post your findings
Jan 12, 2009 | HP Pavilion ze2000 Notebook
External monitor
This does not appear to be a display issue but more of a failure of explorer to load. Try pressing Ctrl + Alt + Del so it brings up task manager. Click file then go to new task and type Explorer and see if all of your icons and such show up. If they do you will want to install a spyware remover such as spybot search and destroy from safer-networking to check for any spyware that is preventing explorer from running. Also check your event viewer in safe mode and see if there are any errors when you boot.
Dec 19, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
